Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Need to change ground drive belt on poulan riding mower model po15538ct
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 376 Answers
SOURCE: Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
Posted on May 28, 2009
mowerman1857
  • 389 Answers
SOURCE: What is the belt number for a 38 inch Poulan
Assuming you mean the deck belt, since you don't specify, it is part number 144200 The same as Craftsman. AYP, Poulan, and several others. You can purchase it at most sears stores or order it on line
Posted on Sep 29, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Poulan riding mower and it has a 42
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
Posted on Oct 31, 2009
Starts but wont drive
Sounds like your drive belt came off the pulley. Look at the bottom of the engine. If you see a loose or broken belt, that's the problem.
Aug 29, 2016 | Poulan Garden
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Directions for installion of the drive belt
Go to the Poulan Pro website and click on user manuals. Enter your model. I nstructions are in PDF form.
May 12, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
May 28, 2009 | Poulan Garden
Trying to find the belt size for a poulan riding mower
yuo need the serial number model number etc and find a websiter who sells em or go to somwere that repairs mowers and have them order one
Feb 26, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
