Question about Amana DLW330RA Top Load Washer
How do I replace the spin cycle blet on an Amana model #DLW330RAW, What is the belt number so I know I'm ordering the right part, Where can I find some installation intructions? Bob
    President:
  • 1,932 Answers
Please check the below website
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Washer-Parts/Model-DLW330RAW/1268/0153200/M0603029/00008?blt=06&prst=&shdMod=
In this website they have given all the part number and exploded view of your model machine.So that you can order the spin belt accordingly.
Thank You
Posted on Oct 06, 2010
Amana washer model dlw330raw will not spin please help do you have any videos to help me fix this problem
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Mar 30, 2015 | Amana Washing Machines
My Amana Washing machine model DLW330RAW makes a loud high pitch sound when on spin cycle. Could you tell me what it is?
loose drive belt ,if you have this noise then your clothes are not getting washed proply.adrian,,,,
Oct 30, 2010 | Washing Machines
I have an Amana Distinctions Washer DLW330RAW. I put a load in and in a couple of minutes had smoke. Shut it down and found the belt was broken and slightly burnt. I have replaced the belt but the...
The transmission is burned out. The same exact problem just occurred with my Amana Distinctions. Whirlpool will pay for this repair 'by concession'. Call the 800 number inside the lid and explain your problem, the operator should offer a free diagnostic visit and the repairman should offer free repair.
Aug 13, 2010 | Washing Machines
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
On my direct drive model number DLW330RAW how do I get the belt back on around the pump pulley?
use a screwdriver. put on the small pulley first - then the big one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Amana Washing Machines
Replace a belt on a amana dlw330raw
you flip the washer on its side
remove the screws on the side
take out the tub springs
remove the pulley
put the belt on bolt on the pulley
put the tub springs back hardest part in my opnion
replace the screws
test the washing machine
....it is no different than changing a belt on a car ....my best suggestion is that you take pictures at every step and stay organized...that way u can tell orientation of all the parts.
Dec 28, 2008 | Washing Machines
Amana DLW330RA Top Load Washer Logo
184 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
