Question about Pool & Spa
Draind and filled my hot tub (cal spa). electric heat. once i filled it back up and turned breaker back on. when the heater kicks on it kicks out the breaker.
  • 990 Answers
When you drain and refill most spas you will get an air lock in the plumbing. You will need to find the drain valve and open it to flood the pipes. It's possible you may have burnt the element and may have to replace it. Hopefully the breaker kicking spared you this expense. Myself I burnt two of them before I learned. Good luck.
Posted on Oct 07, 2010
Have a cal spa and error code OH came up. I shut down the spa for a day and error code is still there and water is no longer hot
Sounds like your high limit has tripped. Most cal spas have a red stem/button on the front of the control box. If you press this in then it will reset and you will be able to heat the spa. You'll have to remove a panel to get to the control box as it is under the spa. It may have tripped because the thermostat is bad and it continued to heat above 104 degrees. We carry a full line of Cal Spa parts at poolsupply1.com
Nov 03, 2014 | Pool & Spa
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
Rod
US Parts Center
888-521-6183
Dec 19, 2012 | Pool & Spa
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does oh mean on hot tub a cal spa
'OH' means 'over-heat'.
Basically the high-limit temperature sensor has detected a temperature far in excess of what it should be.
Check the filter(s), water flow, pump etc....
Regards,
Ian.
http://hottub.synthasite.com
Jan 26, 2010 | Coleman (5040B750) Patio Heater
Pool & Spa Logo
237 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
