Question about Dell Inspiron E1705 Notebook
Can't connect to my wireless network via my Inspiron E1705
It's picking up the signal without any trouble but I get the error message about wzc and article 871122. I've tried following the instructions in the article but it says I have to follow the instructions from the manufacturer (Dell) for my wireless card. My machine's not under warranty any more so Dell won't talk to me.
Help!
    Sergeant:
  • 458 Answers
Use the program that came with your wireless card. Do not let windows do the job. You will find this in your wireless settings. Is it the wireless device that came installed in your computer or an external device? Look at the wireless card and let me know what brand it is. This will help me with your problem. On your laptop you will have to take some screws off of the back to get to the card. Make sure that it is hooked up.
Try this link here and see if it helps.
Posted on May 29, 2008
How do i get my dell inspiron E1705 to connect wirelessly?
First of all make sure the Wifi is turned on your laptop.
You need to press Fn+F2 at the same time to turn the wireless on. Once its on you need to connect to the wifi network in range and you are good to go.
Thanks
Oct 11, 2012 | Dell Inspiron 1525 Laptop
My laptop recgonizes the wireless network but it will not connect to it.....help please.
After it recognize it you have to pick the wireless connection you what to use, go to the bottom corner, of the lap top and open the wireless connections, and pick the right one to use.
Jun 08, 2011 | Dell Inspiron E1705 Notebook
When I try to connect using Wireless Network connection the following error message now appears: "Windows cannot configure this wireless connection. If you have enabled another programme to manage this...
Your obviously having a network configuration issue. Go into Network icon, set up a network connection, make sure you have Wi-Fi and that your laptop is picking up the signal then manually set up or scan for the wifi access point, your laptop should pick up the access point and a name should appear for that wifi spot. Once that is done then you can rename your access point with your name or HOME whatever you like, its hard to explain through here.
Jun 13, 2010 | Acer Ferrari 4005WLMi Notebook
Suiddenly lost my wireless connection. (Dell Inspiration E1705)
make sure the wifi enabled and wifi light is on. to enable it press "Fn" and "F2"
Feb 19, 2010 | Dell Inspiron E1705 Notebook
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1705 Do I have a switch or keystroke to turn on wireless capability"
you should have software that came with Dell but failing that you can use Windows by clicking connect to on the Start Menu
Mar 31, 2009 | Dell Inspiron E1705 Notebook
How to fix intermittent wireless signal with Dell Inspiron 1501
It's the Wireless Zero Configuration service that's doing it. Every 10 minutes or so, the WZC service goes out and tries to look for wireless networks. During this time, it can sometimes disconnect from your wireless network. Usually its brief, merely a few seconds, but long enough to kick you out of games, messaging clients, etc.
There is no easy way to resolve this other than stopping the WZC service after startup and successful connection to your wireless. Unfortunately, if you disable this service altogether, your computer will never connect to any wireless and when looking at the Wireless networks list, it'll mention the WZC service is disabled.
You will also need to re-enable this service everytime you take your PC to places where you'll be connecting to other wireless networks. To stop this service, follow these steps:
  1. Go to Start -> Run -> and type "services.msc" (without quotes)
  2. Scroll to the very bottom of the list
  3. Right click on the Wireless Zero Configuration and choose stop
Once it stops, continue working with your wireless network. If you no longer have disconnection problems every 10 minutes roughly, you've solved your problem. Repeat the above steps after every reboot as the service will be re-enabled after the computer restarts.
Mar 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Secure Wireless Connection Says It's Out of Range
Follow the steps in the SecureW2 user guide to make sure that "Enable IEEE 802.1X authentication for this network" is enabled.
User guide here: http://www.securew2.org/wiki/UserGuide
Feb 06, 2009 | Dell Inspiron 8600 Notebook
TRYING TO CONNECT WIRELESSLY TO THE INTERNET DOESNT WORK
wow! thats a very nice wifi card. prism.
anyway, here is a link for your windows 2000.
this connects you to any wifi hotspot other than boingo.
cheers
Mar 27, 2008 | Fujitsu LifeBook P1120 Tablet PC
Not pickin up signal
Upgrading the firmware (which forced a software reset) solved a similar problem I had with an SMC router. Have you tried logging into your router via an ethernet cable and doing a software reset? If you try this, be sure you have all the information you need to set up your wireless network again because the reset will wipe out all this information.
Nov 12, 2007 | Belkin (F5D7230-4) Router (587009)
Dell Inspiron E1705 Notebook Logo
430 people viewed this question
Alun Cox
