Question about Acer Aspire™ T180 PC Desktop
My desktop screen is blinking & showing nothing. cheked the power cord & it is working. what could be the solution?
  • Acer Master
  • 7,733 Answers
A BOOT failure.
Posted on Oct 06, 2010
Dell dimension c51 desktop pc, when I hit the power button the fan runs load but doesn't come on?
Please check the VGA cable (attached pic) and the power cable of the monitor, see if it works. Also, please confirm if you see a blinking cursor on the top left corner screen or if nothing shows up
Jan 08, 2016 | Dell Computers & Internet
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Hp cpus power supply green light constantly blinking
As always verify all cords are plugged in properly. After that it sounds like you power supply went out. It is not that hard to replace. Make sure you unplug power cord. After you remove the pc cover, Usually you just need to unscrew 4 screws for the power supply. Somewhere on the power supply it should say how much watts it is. Anywhere from 200 watts and up. Just replace with exact wattage.
Sep 16, 2009 | HP Media Center m7250n (ED842AA) PC...
My modem light on my router blinking
You mean the power light? Or a light to the port you are plugged in to? It is normal to have a blinking light where your ethernet wire is plugged in. It shows that it is working.
Aug 28, 2009 | Belkin Computers & Internet
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
Booting problem
the ram may be faulty try to change the ram with one which is working
May 21, 2008 | E-Machines eMachines Desktop PC
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Acer Aspire™ T180 PC Desktop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
