Question about Vivitek V37835 46 in. LCD Television
T3647276/VIVITEK TV IS JUMPING VERTICAL ROLLING ON THE SCREEN
Ii have a old panasonic tv n the screen keeps jumping. How can I stop this?
Hello
The fault [vertical rolling, jumping] will be due to some value detereated electrolytic capacitors at the vertical output section of your tV. Repalce all the eelctrolytic capacitors [5 or 6 of them], on the vertcical output section on the main board.
Mar 14, 2012 | Panasonic Televison & Video
Tv picture rolling vertically
Vertical oscillator and output section should be trouble shooted. It is a skilled job.
Mar 09, 2012 | Zenith Televison & Video
Picture is rolling jumping horizontally andvartically
you must change some condensators near vertical IC in tv chasis....
Nov 30, 2011 | Televison & Video
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
TV SCREEN KEEPS ROLLING
you a "ground loop isolator" its a little plug in filter for electrical feedback.
Jan 03, 2011 | Vivitek V37655 56" DLP TV
WHAT CAUSES A COMPUTER SCREEN TO KEEP ROLLING
sounds like either the monitor or internal video card is dying, the rolling would be the equivalent of vertical hold button on a old crt tv
Mar 09, 2009 | HP Pavilion dv9000z Notebook
Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jan 28, 2009 | Sharp 13VT-K100 13 in. Combo
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Vertical Hold Problem when connecting DVD Player
they have different resulutions they can synk
Nov 18, 2007 | JVC AV-32432 32" TV
Vivitek V37835 46 in. LCD Television Logo
20 people viewed this question
Top Vivitek Televison & Video Experts
matt martin
matt martin
Theo Nikolaidis
Theo Nikolaidis
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
