Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
When the power head is activated. The brush housing vibrates and make a very load noise. this started all at once one us and no problem next use and it sounds as if it wants to come apart
  • 377 Answers
Sounds like you need to check the alignment of the beater brush drive belt. If it is torn or loose, it will cause you trouble. Best to go through the process of replacing it and at the same time, clean the beater brush and make sure it is not frozen. If it is it can cause problems for the drive belt. Pay special attention to the ends of the brush where the clips are that hold it in place. Spray some WD40 and turn by hand to be sure the holders turn freely.
If you find this solution to be beneficial, I would appreciate a Thumbs Up rating from you.
Be well, Paul
Posted on Oct 06, 2010
My Hoover makes louder noise when the brushroll is on. I just cleaned but no result.
What kind of Hoover is this? There are a few things that will cause excessive noise and vibration such as a worn belt, the wrong belt, damaged end caps, damaged brush roll housing and worn bearings. Inspect the brush roll area. Remove the belt, if you have a spare, check the size. If it's more than 6 months old, replace the belt. Spin the brush roll in the housing, does it spin free or hesitate or not turn at all? If it spins with effort there could be debris under the end caps; if one end cap will not turn there is enough debris to cause the end cap to internally melt to the roller. If you cannot turn the brush roll by hand, replacement is your best solution. You should also inspect the housing where the roller spins, specifically where the end caps sit; look for damage to the slots in the plastic, it the roller will not sit snug this could cause enough vibration to make the sound you're hearing.
Sep 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Turbine Head Brush Tool - Noisy
See if there is something wrapped around the brush area itself which could cause the noise
Jun 06, 2012 | Dyson Vacuums
How do I change the belt on my Sears vacuum?
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 15, 2010 | Kenmore 25512/ 25513 Progressive Canister...
How do you open the power head to remove the beater brush on a kenmore 116 canister? I have a piece of twine wrapped around the end of the beater brush
Greetings,
Thank you so much for that clarification, I know the exact model of Kenmore that you have now. This model is actually made by Panasonic for Sears who puts the Kenmore name on it. I wasn't able to located the Sears owners manual, but I did find a Panasonic model that uses the same power nozzle as yours does. I will also explain how to access the roller brush below, and if you'd like to see diagrams of how to do it, you may visit the link below to the Panasonic owners manual. Start at page 46, then go back to page 40.
http://service.us.panasonic.com/OPERMANPDF/MCCG973-MUL.pdf
In order to access the roller brush on this model, here's what you need to do. Underneath of the headlight cover, there are two screws that need to removed first. In order to get to these screws, simply push on both sides of the headlight cover, and lift it straight up while pushing both sides. After the headlight cover has been removed, you'll be able to visibly see the two screws that need to be unscrewed (phillips head screw driver). Remove these two screws next.
After the screws have been removed, turn the power head upside. If you look at both the left and the right sides, you'll see a little indentation on each side. All you need to do is put a flat head screwdriver in these indentations, and pry up on both sides. This will remove the top housing. Once you have top housing removed, you'll see there's one more cover that goes over the roller brush. There are two tabs on both sides behind the roller brush. If you squeeze these two tabs, you can now remove the white colored housing that covers the brush, and have full access to the brush.
I hope that this helps you remove the twine from your beater bar. If you found this repair helpful, please be sure to rate it by clicking the thumbs up icons in the top right hand corner. If you have any other questions about how to repair this, please feel free to request a clarification, or add a comment to the repair, and I'll be more then happy to help you.
Thanks very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
I have a Filter Queen Majestic 360 and am having problems with the powerhead. There is a loud rattling noise in the powerhead, especially when I vacuum thicker carpet. I have replaced the motor, roller...
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Feb 20, 2010 | Filter Queen Majestic Canister Vacuum
THE ROLLER IS DRAGGING AND MAKING A NOISE
Your drive belt is probably streched and slipping on the motor shaft. However your bearings on the roller brush may be worn out.
Take roller brush out of power head and check the bearings at each end. If they are siezed buy a new brush.CHeck to see that your brush housing is not damaged due to heat caused by siezed bearings
Nov 16, 2009 | Vacuums
Shark v1510 How do I replace the belt?
remove the outside sliding cover... remove 2 screw in from of housing, and also the screw holding the wheel on the brush head cap side of the housing. Once screws are rmoved, you can remove brush head cap and belt cover. Pull down on belt cover to remove. It is held by screw crossing the top of the cover from the side. Belts are hard to find, but can be ordered from shark web site (2) for 7.95 and shipping.
I had the same problem. Some one should stock these belts in the states, because Shark outsources thier call center to India, which sucks. It took 20 minutes on the phone to communicate through the noise and language barrier just to order a belt!
Oct 23, 2009 | Vacuums
UNABLE TO FIT BELT ON MY ULTIMATE UPRIGHT G BAG VACUUM CLEANER.
You need to disengage the carpet head from the vac itself. Do this by lifting the headlight and rotating the thumb lock underneath. Then release the carpet head by turning the square dial below the light. Once you have lifted the head off the vac you will see from the backside of the head there is a belt hook holding the old belt in a twist.
pop the brush cover off at the bottom of the head but note which end of the brush goes right and left. Slide the new GENUINE belt onto the brush roll and inspect the brush for hair and thread caught at the ends.
Reisnatll the bottom plate in reverse order making sure the brush sits level in the housing.There are leveling blocks at each which are color coded.
Once again rotate the square dial on the front of the housing, in both directions if necessary ,You will feel the dial tension as it hooks your new belt inside the housing and twists it into installation position.
Reinstall the head in reverse order onto the vac.
Aug 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Makes vibration noise when the brushes are on
if you caught anything like a shoe laces or anything that may stop the brushes, it could be that the agitator will have to be replaced. you can tell by looking at the agitatior where the v-belt goes. if there is cut grooves or plastic build up from the brush stopping. then the v-belt and agitator would have to be replaced. hope this helps
Mar 26, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
76 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
