Question about Maytag Neptune MDE5500AY Electric Dryer
Seems to work and get warm but takes more than an hour and half to dry light loads of clothes
  • 44 Answers
Take the filter out and run it under water, see if the water flows through the mesh. Sometimes there is an oily residue that blocks the holes in the mesh. If it holds water, wash in warm soapy water and try again. If water flows through this time, re install filter and try machine again. I hope this helps
Posted on Oct 06, 2010
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Dryer takes forever to dry clothes
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
35 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
