Question about Maytag Neptune MAH5500B Front Load Washer
The maytag neptune washer gets stuck at 8 minutes to go. I unpluged it for about 8 hours and it seemed to be alright; now it is doing again. The washer is about 4 or 5 years old and it's just me and my husband; about 5 loads a week.
jsrock516
  • 5911 Answers
SOURCE: CLOTHES STUCK IN WASHER!!!!!!
If you open up the dispenser tray on the top of the machine, there should be a red cord. This is the manual release for the door. All you have to do is pull this cord and the door opens. If the cord is missing, you will need to remove the top of the washer to get to the latch. I hope this helps you.
Posted on Jul 16, 2007
  • 109 Answers
SOURCE: Maytag Neptune MAH400AWW
rear tub bearing is going out, must be replaced, causing too much drag. labor intensive repair.
Posted on Mar 30, 2008
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
make sure it is installed correctly - there are 4 yellow plugs at the back that need to be taken out.
Posted on Jun 20, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Door won't open -washed a load of towels and door seems to be stuck. unplugged and waited so computer would reset but it didn't work. its a maytag neptune.
unscrew the soap cover. you will find a nylon cord usually red or green. pull that and the door will unlock. then replace the lock unit
Dec 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wont start
Try unplugging the unit for an hour allowing the microprocessor to reset. Plug it back in and use as normal. Let me know if this helps.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can't get washer to start.
Try unplugging the machine for 30 minutes. This may reboot the electronics. If not the controls are damaged and may need to be replaced.
Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptuneMAH9700 front load washer
Another computer generated flaw.The worst thing is alot of times that "flaw" can be a costly one
May 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer 9 min
check your pump for obstructions, including the filter
Apr 22, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
191 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
