Question about Samsung DMR77LHS Tall Tub Dishwasher
My samsung dmr77lhs LE light keeps flashing how do i reset this garbage machine? Resetting the power does not work. Please help
I have the same problem with my dmr77. My coffee pot ran over and evidently ran down behind the Samsung dishwasher. It thinks that it is leaking. How do you reset it?
Posted on Oct 26, 2010
I just bought a house with an lg washer. I ran a load of towels and the screen says "LE see owners manual". What's wrong?
Hi
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load. ... But if the error code displays on every washing cycle, the unit will require a repair service. How to reset the washing machine: Press POWER to turn the washer off.
I hope this helps Nick
Dec 30, 2017 | LG Washing Machines
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
DIGITAL DISPLAY SAYS LE
Hello, W/D here.
The LE code indicates that the dishwasher thinks that there is a leak, and the leak detector shut the machine down and displayed the LE code.
If you in fact have a leak, it should be repaired either as warranty work or by a reputable repairperson. The LE code can be reset by turning off the circuit breaker controlling the power to the dishwasher for several minutes, then resetting it.
If you have a stainless dishwasher, it is guaranteed for life (usually) against leakage. Samsung will require a service call by their tech, and if the unit is unrepairable, will depreciate the unit before offering a refund. Not great. The good news is that these are fairly robust machines, and leakage might be no more than the door seal. Check the seal and reposition it if necessary, as they not only tend to flatten out, but they also tend to pull out of their grooves holding the seal in. It seems that in making the "tall tub" types, there is less space between the racks and the seals. Larger objects, especially on the upper rack, can bump the seal and pull it out of position a bit, creating a leak. It doesn't take much.
If you bought your machine from one of the major hardwares, and you got the extended warranty, they will make three attempts to repair the unit, then replace it if unsuccessful.
Hope that this was helpful to you. --W-D--Please feel free to rate this solution. Thanks.
Feb 21, 2011 | Samsung Dishwashers
A screw fell inside the tub I took the bottom sreen apart it was uder the base were the impeller is, took that apart, put everthing back together and went to start the dishwasher up and the LE code...
try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE problem.First disconnect all power ( power supply, circuit breaker, wiring etc) to the machine. Disconnect all tubing to the machine ( drainage pipe and braided hose feed) Then you need to take out the dishwasher, turn it over and then remove the large white sensor tray that will expose the leakage sensor held on by 2 screws. Remove the screws and dry up the sensor tips (4) with a dry towel and dry up the tray all around as well. Replace the tray and re connect all tubing and power. You're problem should be solved and you just saved yourself a pile of money in service repair bill. M.D.
Dec 22, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
I have an LE code how can i reset
Try unplugging the unit for a few minutes. Then plug back in. If not try the Power button. I have an SE code (drainage problem) and my machine stops running altogether.
Sep 05, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Badger disposal keeps turning off after about a minute
unplug the unit from the wall.take a strong flash light look into the unit. there is something in there.the braker shut-down only when the motor is over loasded. meaning, there is something holding the blade.
Jun 01, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
R-800 printer will not funtion. Red light on the Garbage can/aper keeps blinking.
is your printer dirty? check the rollers on the back of the printer and the top and make sure the rollers are clean..also check for paper thta may be stuck in rollers or paper clips...make sure your using the right type of paper....try resetting the printer, unplugging, waiting for about 20 seconds then plugging back in. Check and make sure connections are all securly connected...if none of this works you could have a hardware problem.....if you have a warranty it would be a good time to call them...if not a local computer or hardware repair shop will also work
Apr 16, 2009 | Office Equipment & Supplies
Samsung DMR77LHS Tall Tub Dishwasher Logo
1,807 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
