PROBLEM IS SWITCHED ON TV ATOMICALLY CHANGING CHANNELS AND VOLUME NOT ABLE TO OPERATING.....
    Problem Solver:
  • 9 Answers
Stay calm, first of all. Try not to get frustrated. You most likely have stuck buttons. The first thing I would try is to take a toothpick and gently pry at the buttons that aren't working. If that doesn't work, take the remote apart and push from the inside on the buttons. If that doesn't work, you may need to purchase a new remote, at walmart for maybe about $8.
Posted on Oct 06, 2010
Why is the Goodmans digital box remote not changing the channels or volume on My Daewoo TV?
Think about it. The digibox remote should only change its own channels, not the TV ones. Otherwise the TV would never be on the correct channel to see the digibox signal.
As for the volume, unless the Goodmans remote is programmable to emulate the TV volume, then it will just change its own volume. The result is the same. The TV gets louder or quieter.
Sep 03, 2014 | Televison & Video
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
Changing channels
A common issue with this model is the control key board (the key input board that has the buttons on the cabinet of the TV).
This board can cause a lot of issue ,from changing channels by itself,to intermittent shut off, also sources cannot be switched or they switch by themselves.
The less common issues would be the remote eye or the main board.
If you give the full model number and the product code from your TV, I can give you the part numbers.
Apr 01, 2010 | LG 22LG30 22 in. LCD HDTV
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Channels
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
