Question about HP Pavilion dv6000z Notebook
My webcam has purple lines running though it - HP Pavilion dv6000z Notebook
Tip
Solution to the HP Purple Web Cam Issue
This document is located on HP's web site concerning purple tint on certain web-cams.
This document pertains to certain HP Notebook PCs with Windows 7.
When using an HP ENVY 15 notebook PC webcam in low light conditions, images on the webcam may have a purple tint.The ENVY 15 Series webcams include night vision technology that is designed to operate in normal lighting conditions and optimized to operate in low and zero light conditions.The webcam night vision feature includes two Infrared (IR) lights located on each side of the webcam and behind the display panel bezel.
Low to zero light conditions will cause the webcam IR lights to activate. The IR lights provide illumination for low and zero light conditions and help prevent fuzzy images that are typically associated with operating standard webcams in low and zero light conditions.
Turn off the webcam IR lights. While some degree of purple tint may be present under low light conditions, turning off the webcam IR lights will reduce and in certain cases eliminate the purple tint.
  1. Select Start > All Programs > HP > HP MediaSmart > HP MediaSmart Webcam .
  2. In HP MediaSmart Webcam, select Settings > Display > Advanced Settings , and then click the Camera Control tab.
  3. Select the Low Light Compensation check box, and then click Apply .
  4. Click OK .
NOTE:Disabling the webcam IR lights will cause display images to appear darker in low and zero light conditions.
The webcam IR lights are also available on other webcam programs.
Refer to the software Help for additional information.
This document will be updated if additional information becomes available.
on Jul 28, 2010 | Computers & Internet
How do I use the tool for detail sanding
See the purple line on the poster:
http://www.dremel.com/en-us/customerservice/ManualsAndLiterature/Documents/2012AccessoryPoster.pdf
I like the cylinder ones. Run it on slow speeds to get used to how it moves. It's probably not a great choice for sanding anything you want flat. They are great for shaping curves though.
Sep 09, 2014 | Tools & Hardware - Others
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
Toshiba Webcam image shows purple/green lines...
It might be a cause of software which you download or some malfunctioning in the hardware, try resetting first before reintsallation of driver or replacement of the cam.
Jan 22, 2012 | Toshiba satellite c660
I have a purple line running up and down my 42" sanyo?
Hello; If this purple line goes fully from top to bottom, You have a bad LCD panel. If the line goes only part way down or up the screen, You likely have a cracked LCD panel ( never covered by warranty ) The LCD panel will cost more than the set sold for ! John
Jan 22, 2011 | Televison & Video
I just installed my Logitech Webcam C120m and it has white lines all over the picture. I reinstalled everything and it still has the white lines.
You could try twisting the lens if it twists. My webcams twist to adjust the picture. It's just a suggestion i don't know if that will work or not. If i helped you please leave me a rating.
Mar 03, 2010 | Logitech Webcam
Cam has green and purple lines through it . i have hp laptop and the cam is built in,,when i cam up i get green and purple lines through it,,,can't seem to make them go away
Either The Display Cable Is Faulty... Or You Need To Re-Seat The Webcam Ribbon Cable...
THis Means You Will Need To Remove The Front Bezel Of the Screen
Dec 04, 2009 | HP Pavilion dv6000z Notebook
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
HP Pavilion dv6000z Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
