Question about Dacor ECS230 Epicure Electric Double Oven
Dacor oven clock button not working. Power went off and clock needs to be reset. No error displays- oven works fine. Reset power breaker. Still showing incorrect time- clock button is not beeping when pressed. What do I do in this situation?
  • No Religion
    No Religion Dec 21, 2014
    I have this same problem. No beeping when pressing the Clock button. Does anyone know how to fix it?
  • jimmy1946 Nov 30, 2016
    This has happened to me at least twice per year since 2004. Solution is leave it alone for 3 to 5 days. Touch the clock button everyday until it finally works. Trust me the clock button will reset. I put a piece of masking tape over the time and hit the clock button everyday sometimes twice per day. After about 3 to 5 days it will beep and you can reset the time.
SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Posted on Feb 24, 2008
  • 87 Answers
SOURCE: Oven Won't Work!!
Replace the elecronic module
Posted on Jun 10, 2007
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
  • 5 Answers
SOURCE: dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Posted on Aug 25, 2009
SOURCE: Dacor error codes
I had the error code F 0.
I unplugged it and plugged it back in.
This fixed my problem.
Here is a link to Dacor's error codes.
http://www.repairclinic.com/0078.asp#Dacor
Posted on Mar 12, 2010
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
We clean are double wall oven and I can,t reset the clock.
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Dacor ECS230 Epicure Electric Double Oven
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
Power was turned off. I reset the clock to proper
We have the exact same problem. It doesn't heat to above 135. Help!!
Jan 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor ecs230 clock button is not working
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Dacor oven ECPS127S will not heat after self clean
Feb 16, 2008 | Dacor ECS127 Epicure Stainless Steel...
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Dacor ECS230 Epicure Electric Double Oven Logo
946 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
