Question about Epson TM-H60000II Thermal Printer
Cheque stuck in tm-h6000II
HOW DO I TAKE OUT A TORN CHEQUE FROM THE PRINTER
    Genius:
  • 1,447 Answers
Try this- remove the ribbon and try to pull specks of paper
Posted on May 28, 2008
Tm h6000II
I guess it lacks either a thermal roll or something's wrong.. like.. error code? check your printer software, usually displays an error code or says what the problem is
Jul 24, 2013 | Epson TM-H60000II Thermal Printer
Can you tell me what the default dip switch settings are for an Epson TM-H6000II receipt printer with a serial interface Thanks!
http://www.bluestarinc.com/techsupport/epson/Dip_SW_Settings/Default%20DIP%20SW%20Setting_Rev%20D.pdf
About halfway down.
Also:
http://www.beaglehardware.com/support6000.htm#DIP_Switch_Settings
Jul 25, 2011 | Computers & Internet
My Clarion application sends codes directly to the (TM-H6000II) printer. I need to print in Hebrew but the printer seems to insist on Greek (I think!). I added the following code to the printer start: ...
This most likely requires that you get the Hebrew Font set from the Manufacturer and install it in the Printer Firm ware or update the Hebrew Font Set in your computer software. Either should resolve your problem. The printing that you currently see is, without actually seeing it, the result of the printer trying to print character codes that it does not recognize. I would try updating the Firmware in your printer first then if that failed update the Hebrew Font codes and character set and install that. Epson should have the download on their website. The information you need for the software Font download will depend on what software you are using.
Aug 31, 2010 | Epson TM-H60000II Thermal Printer
Can't find driver for Epson TM-H6000 for Vista 64-bit OS
hi.
hi i have a same problem as u have. but for now i am using generic driver using generic text drive only. and pls dont forget to keep ur port as com1 plus change ur bit to 19200 otherwise that also will not work.
Feb 27, 2009 | Epson H6000II Thermal Printer
Error light on a Tm-H6000II
Whats the pattern of the blinking light? can you pls describe...
what type of interface are you using, USB, SERIAL, PARALLEL, ETHERNET?
Apr 30, 2008 | Epson TM-H60000II Thermal Printer
Receipt printer TM-U220 not working
After looking at the description of this printer, the following suggestions: 1. This uses an external power supply- is the printer power indicator lit? If not, then perhaps the external power supply is dead, or the connection where it plugs into the printer is broken. Sometimes the connector can itself be broken, or where it solders onto the circuit board, causing a dead condition. A break in the wire also. 2. If printer is getting power- check the paper path for something foreign lodged- a torn piece of paper etc. 3. There should be a paper present sensor somewhere also, which checks if the unit is out of paper. There is possibly a lever which contacts the paper- check if this lever is broken or stuck. 4. You could try printer on a different computer, to narrow the problem to either the printer or to the computer/cash register. 5. Have you checked the software? Is printer properly setup (drivers), and set as the default printer? Does a printjob appear in the queue? Lastly, there could be a problem with the electronics, which would require technical repair, or replacement of the unit.
Sep 11, 2007 | Epson TM-U220 Matrix Printer
Epson TM-H60000II Thermal Printer Logo
117 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
