Question about Nikon COOLPIX S60 Digital Camera
My Nikon Coolpix s60 won't turn on- what should I do ? The battery is fully charged.
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
  • 1382 Answers
SOURCE: nikon coolpix s60 lens error? the lens won't
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Aug 17, 2010
Testimonial: "thanks!!!!!"
  • 102366 Answers
SOURCE: what does it mean when
It means the card has been protected from writing, preserving its current contents.
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Dec 08, 2010
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
SOURCE: when i turn on my
when I turn on my Nikon Coolpix S210 digital camera on it says battery temperature is high and I cannot use my camera. Why?
Posted on Feb 22, 2011
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn onĀ¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
My Nikon Coolpix S3100 won't turn on
I had the same problem, and many other people have had this issue. The camera sat for too long, and the battery fully discharged. It needs to be reset. In order to do that, remove the battery and memory card. Replace only the battery, and plug it in. You should see a green light flashing to the right of the LCD screen. That means it is now charging. Replace your memory card, and let it charge before trying to use it.
Apr 30, 2012 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
My nikon s8000 wont turn on. It is fully charged, but will not turn on when I press the on button.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Nikon COOLPIX S8000 Digital Camera
Nikon coolPix 2200 will not turn on.
Hi
Try doing basic troubleshooting, turn camera offf, remove the battery. Reinstall battery after a minute or two and try turning it on. Make sure battery is fully charged.
Hope this helps
Sep 16, 2010 | Nikon Coolpix 2200 Digital Camera
Nikon COOLPIX S60 Digital Camera Logo
332 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
