Question about Canon PIXMA MP530 All-In-One InkJet Printer
How do I get the printer to connect with my laptop. I'm pretty sure I have the cable connected correctly. The copier function works fine. It worked fine w/ my old laptop over a year ago, but that was stolen and I have a different model but I'm not having any luck down loading software.
  • Canon Master
  • 7,733 Answers
Go to the Add hardware wizard or uninstall / install again.
Posted on Oct 06, 2010
My Hp office-jet Pro X576 printer is connected via a network and if l send a print job it displays printer error switch off machine and the printer restarts .if l use usd it works fine
I would ensure that you have the current firmware installed on the printer and make sure that you are sending the job via network with a correct driver. If you manually set the IP address on your computer and the printer you should be able to connect direct using a crossover cable, I do that in the shop all the time.
Dec 11, 2014 | HP Officejet Pro X576dw Network-Ready...
Having a problem scanning. Worked fine now brings up a message saying the cable is not plugged in but it plugged in correctly
Try a different USB cable between the printer and your computer.
Try connecting the printer to a different computer, e.g., a laptop, to see if the printer is recognized by another computer.
Jul 25, 2011 | Office Equipment & Supplies
I have dell 926 all in 1 printer,a dell inspiron1525 laptop i have uninstall/install the drivers from dell 3 times,print jobs Que but not print via laptop,not even a test page
Hi
Did you use the printer before that is connected to your laptop and prints fine or you are setting up the printer but unable to set up?
Before that check that all the cable connection are connected. Remove and connect it again, then when setting up the printer, check if it is reconized by your laptop by adding and setting up the printer once more.
Check also the printer's compatibility with the operating system? and install the correct driver?
Check also the USB cable and make sure you are using a USB cable port?
Please post comment for more help. Regards
Mar 31, 2011 | Dell 962 Photo All-In-One InkJet Printer
HI, my laptop is running windows 7 and i am trying to instal an hp series 5150 printer. I have downloaded the printer drives from their webpage but nothing works. Please help me.
First, make sure that you have downloaded the correct drivers and installed them correctly. Drivers are available for two versions of Win 7, 32 Bit and 64 Bit. Click here and make the selection accordingly (32 Bit or 64 Bit).
Secondly, make sure that the printer and cable are functional and when you connect the printer to your laptop, windows detects it. If windows is able to detect the printer, it should work, otherwise the problem could be with the printer or cable.
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Nov 30, 2010 | Office Equipment & Supplies
Printer not working with new laptop
Here is a link for the driver. http://my.okidata.com/PP-C5500n.nsf?opendatabase Is this what you are using? Mark
May 07, 2010 | OKI C5500n Printer
My scan gear software cannot list the cannon ir2022 copier. The Ethernet network plug also doesn't blink when connected to the slot in the copier? please respond me with ermiasabate@gmail.com thank you
first are you sure that you have correct network cable, plain utp if you use copier over hub or similar and cross if You are connected directly trough PC.
Under cmd, type: ping xxx.xxx.xxx.xxx. "x" means the IP adress, if you have replay without 100% loss, the copier communicates fine with pc.
If not use cross cable and connect directly to pc or laptop.Do not forget adjust laptops gateway, and subnet same as copiers.Then try again from setup of printer drvivers and scangear. Do not forget to press discover under scangear properties.
Dec 26, 2009 | Canon iR 2022 Printer
What is the cable connection like to a pc?
U need a cable that is USB type A to USB type B, type A is the rectangle, type B is like a square, here is a link to a photo of the 2 types
http://www.folcom.cz/img/USB_konektory.gif
Nov 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
No scan with imac
Make sure that the hardware is functioning correctly.
Restart the product and the computer
Manually check the USB connection between the product and the computer
Make sure that the USB cable is connected correctly to the product
Test the USB connections and restart the computer
The USB cable is connected to a USB hub or a docking station for a laptop
or Desktop.
Fully uninstall and reinstall the HP software
Use the MSCONFIG utility to enable the Startup software
Try the scan again
If the scan is successful, the issue is resolved.
Aug 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
G85 USB failure
You will have to replace the main board in order to get a new USB connection. Have you tried using the parallel connection. Looks like a regular parallel connection but smaller. It takes a special cable that was originally sold with the printer. We have those cables for $15 if needed. The USB cable may be out but the parallel connection may work fine.
Inkworks
866-381-0541
Jul 28, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Canon MP600 - receiving error 20 when trying to print (error 20 = printer not activated). Printer is on and has been working just fine for 1 year.
Check the data cable . Is it connected correctly? Make sure the cable is good.
Don't forget to rate me... :)
May 03, 2008 | Office Equipment & Supplies
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
