Question about Ovens
I have a Siemens oven. The range works fine. The cooktop has intermittent symptoms - I need to verify if has is a short so I can decide to fix it or replace it. 1 element doesn't work and 1 had a permanent 8 lit up. Then all elements stopped working. Sometimes it makes beeping sounds at odd intervals and all the elements show an E. After pushing buttons for a few seconds the beeping finally stops. After weeks of this it will suddenly be better, then repeat the Exorcist cycle. Main question is: does this sound like a short? If not, what is causing it? The model # is HE2416U/ 01 and a manual is here:http://tinyurl.com/2da8twj
    President:
  • 2,777 Answers
It does sound like a short, let me continue to research this but it will be very difficult to pinpoint where it is remotely..
Tim
Posted on Oct 06, 2010
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
SAMSUNG INDUCTION STOVE ERROR CODE E84
Unplug the oven wait 10 minutes plug back in . Cooktop AND Oven working ? Yes - you have a communication problem - display board or main PCB.
Is the oven not working and the cooktop still works ? If yes it is a power problem on L1 or L2 , to verify if the issue is in the oven or the home swap L1 and L2 on the power cord. (if you do not know what you are doing then you should not touch them). If the Error remains yet the cooktop stops working or the cooktop stops and the oven starts working etc. Replace the Circuit breaker in your house panel - it works but not correctly. No Difference check the L1 line and the transformer connector on the oven board - resolder the connectors for the transformer.
Dec 23, 2012 | Samsung Induction Range FTQ307
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
The electronic ignition on my chef cooktop no longer works. Can I fix it myself?
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 27, 2011 | Ovens
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
May 04, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
