Question about Maytag Bravos MTW6600T Top Load Washer
Our maytag 400 bravo series washing machine flashes 5d. Can you help with that error code?
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Posted on Dec 27, 2010
TheMobilian
  • 8220 Answers
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Posted on Oct 22, 2011
My Maytag washer Bravos XL is flashing the code Sd or 5d. What does this mean?
Sd is referring to suds. Did you use too much detergent or are you using the correct detergent. It should say He on container.
Sep 28, 2017 | Maytag Washing Machines
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
Maytag Bravo Washer fault codes
5d is a definitely a the code for a plugged discharge. Clean the filter.
Oct 22, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
My washing machine is a Maytag Bravo, My Manual is packed as were moving, I need to know what the error code LD is and how to clear it
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Make a careful visual inspection of the hoses, and see if you notice anything under the main tub, that could be causing a blockage.
Jun 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Maytag Bravos MTW6600T Top Load Washer Logo
1,006 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
