Question about IBM ThinkPad G41 Notebook
I have done something that makes numbers appear when I hit letters? what corrects this?
  • 699 Answers
On a laptop, if you enable Num Lk (usually by pressing the blue function key Fn and Num Lk), you will enable your numeric keys (as displayed in blue next to the letter). To disable, press Fn and Num Lk combination again (it will 'toggle' out of this mode).
Hope it helps: please vote accordingly!
Posted on Oct 06, 2010
I have an eee pc 1002 i think. its from japan, but i have english windows xp. anyway, the letters U, I, O, J, K, L and M each have a letter assigned next to them. For some reason (i must of hit Fn...
It sounds like you've got the Number Turned On.
Their should be a button with NUM LOCK on it and somewhere on the keyboard and an LED with NUM LOCK next to it which will be on.
Jul 02, 2011 | ASUS Eee PC 1000H Laptop
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
Don
Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
For example, I hit the number '5' and the letter
You are in Num Lk mode. To leave this mode,
press the NumLk key again, a green LED (1) will
go off indicating you are no longer in this mode.
The Num Lk key usually is in upper right corner of the keyboard.
Aug 01, 2009 | Sony VAIO VGN-CR220E/P Notebook
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Typing
Check to be sure that the correction tape is in properly and tight. Then make sure that the ribbon (and correction tape) are between the two metal "fingers" and the cardholder (which is the metal thing that holds the paper close to the platen right in front of the ribbon) Is the ribbon moving? You should be able to hold the ribbon up and see each letter on the ribbon. Also make sure the printhammer is locked forward. You should not be able to just reach in and take the printwheel out without the ribbon in place. The only other thing I can think of, is the ribbon got twisted some how. The dull side should be towards the paper.
Oct 07, 2008 | Brother SX-4000 Typewriter
How can I view an encoded text sent to me
You mean it was password protected when it was created, right? You have to enter the correct password to be able to view it.
Make sure the upper case/lower case is correct. For example, Apple is different from apple. Also, make for the password you are not mixing up a letter "l" and a number "1" or a letter "O" from a number "0".
Hope that helps,
-Vince
Oct 04, 2008 | Gateway GT5220 PC Desktop
Comdial 7260-00
This will fix your issue
Do this:
Feature # *
Hit # (8) times
Hit show
Enter 04-05-101~156 (101~156 is whatever extension number you are trying to change)
Press chg
Use the keypad to change the name pressing # after each letter
When you are done entering the name make sure you press # after the last letter or it won't show
pick up and hang up the handset
DONE
Apr 04, 2008 | Comdial 8324S-PT Corded Phone
IBM ThinkPad G41 Notebook Logo
103 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
