Question about PSC Magellan 8200 (822050510000000) Barcode Scanner
Laser not scanning, no light, error code is 4
I have a canon printer i-sensys MF4410 with error code E301-0001, the problem is that it can not scan and photocopy what can i do to correct this problem?
Code E301-0001
Description
Insufficient light intensity in shading
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
Feb 18, 2017 | Canon I-Sensys Mf4410 All-In-One Laser...
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Code error e100-0001 canon 4410
e100's on canon designate laser failure. there is a mechanical laser shutter that is opened when the front doors are closed. if you look at the door actuators on the inside tops of the door you will see they intersect with the actuators on the machine, make sure everything looks good in that area and the doors close properly. if the laser shutter is not actuated open the bd mirror will not receive the laser light resulting in an error state.
The laser shutter actuators are located behind the toner hopper.
Nov 06, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Recieving error code for my Dell MFD Color laser printer 3115cn when trying to scan a document to a network computer (error code 016-781)
Check the drivers(software)for network printing if correctly configured with your workstation, if so verify if your workstation has network scanning priviladges.
Dec 03, 2010 | Laser 3115cn All-In-One Printer
My Ricoh printer is flashing error code SC230
Looks like the laser unit has quit!
SC230
V-Sync error
Subscan signals are not
asserted.
See SC201.
SC201
Polygon motor error
After the main switch turns
on, the polygon motor is not
phase-locked in several
seconds.
• Incorrect cable connection
• Defective engine control board
1. Connect the cable correctly.
2. Replace the engine control board.
3. Replace the laser scanning unit.
4. Check or replace the cable.
Oct 26, 2009 | Ricoh Aficio CL2000N Laser Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Computers & Internet Logo
48 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
pkwc
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
