Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
Dishwasher powder cap not opening to release the tablet or powder. Dishwasher working fine. Spring in hinge working fine.
  • 4,348 Answers
Be sure the rack is not installed backwards. One direction has an opening and the other has a rod that blocks the door from opening.
Posted on Oct 06, 2010
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
Soap dispenser does not open every time
the spring that tensions the lid is broken or otherwise not working. I would look at the hinge side of the dispenser and see if spring is still intact. When you release the lid, it should snap open without much difficulty so if it doesn't do that, then I would suspect the spring.
May 12, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Jul 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Soap block not releasing while washing
I urge you to only use Electrosol or Cascade powder with your (or any) dishwasher. Most ultra-cheap powder will not clean effectivly. If the dispenser does not open with the powder inside, a service call is the next step.
If you reply, please tell me the Make and model of your dishwasher.Good Luck!
Mar 23, 2009 | LG Dishwashers
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Bosch dishwasher
your not supposed to be using tablets in the bosch dishwasher. the ball on the tablet gets the lid stuck. the sticker on the door recomending tablet is advertisment. your owners manual says to use powder only
Nov 18, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
284 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
