Question about Kenmore HE2 Plus Front Load Washer
Error message F-28 and F-21 on an He2 Plus Washing machine Under warrantee
  • 5,911 Answers
"F28" is a Serial Communications error code. This is an interruption in communicaitons between the Central Control Unit (CCU) and Motor Control Unit (MCU, or the interconnecting wiring between the two.
"F21" is a Long Drain error code. This is usually an indication that something is restricting the drainage system. Commonly, the drain pump reservoir, or inlet line running from the wash tub to the drain pump is clogged.
Since your washer is currently still under warranty, I would strongly recommend you call for service and have a technician resolve these issues for you. Any attempts on your part to disassemble the washer and make any repairs may void your warranty.
The "F28" error code in many cases is caused by a defective CCU which would need to be replaced. Replacement cost (if not covered by warranty) can exceed $200. The "F21" error code, in a worst case scenario can be caused by a drain pump failure. Replacement cost (without warranty) can exceed $150. If the washer is still under warranty, and if any of these parts are found to be defective, they should be replaced at NO cost to you. Honoring your warranty makes better sense in this case.
For a full explanation of these error codes, you can refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
NOTE: Removing the toe panel to retrieve the tech sheet does NOT constitute disassembly and should NOT void any warranty coverage.
If you have any questions/concerns, please post back and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
What does error message f33 mean?
F33 message
check pump drive system error, broken wire, corrosion, junk in pump filter
Feb 23, 2016 | Kenmore HE2 Plus Front Load Washer
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
We cant get the door opened kenmore he2 plus we got it for free and for some reason the door wontt open
Unplug the the machine for a couple of minutes. This should unlock the door. If not, you should remove the lower panel under the door. Simply unsrews 3 hex nuts. Pull the door tab (latch) from underneath. Is there any code error displaying on your LED?
Apr 22, 2009 | Kenmore HE2 Plus Front Load Washer
I have an error code of F-01 on my Kenmore HE2 Plus washing machine. What does this mean and how do I fix it.
Your washer needs to be serviced by a professional. That error code means there is a communication error between the Control Unit and the EEPROM; the CCU needs to be replaced. Check to see if your product is still under warranty.
Refer to page 2 of this service manual:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Mar 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
263 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
