WARNING Drum Life Error for Yellow - Office Equipment & Supplies
    Problem Solver:
  • 9 Answers
You need a new yellow drum for color.
Posted on Oct 06, 2010
Why is the drum error message on after new drum installed and won't print
Hello, you need to reset the Drum Unit life:
After changing a DR2000 drum unit in a Brother HL-2040, the printer's page count needs to be reset. This will turn off the drum warning light on the printer.
Simply open the front cover, and hold the "GO" button until all four LED's are lit. Release the "GO" button and close the front cover.
Jul 28, 2014 | Brother HL-2040 Laser Printer
E000020-01a2 showing this error
This an error code for the yellow color. The E020 is related to toner or drums. The 01 is for yellow but my book doesn't have the a2 part. How long has it been since the yellow drum has been changed? It's good for about 40,000 prints. Go into service mode and go to copier, display, dens, then misc. This will give you the approximate life of each color drum as expressed as a percentage of life. Hope this helps.
Sep 05, 2012 | Canon imageRUNNER iR C2880 Color Copier
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
Canon ir3100cn giving me error code E000020-01a9. how can I go about it?
Hello luvmor. The code means the that when the copier tries to calibrate its colors (gradation) it cant get the yellow to calibrate.This almost certainly because the yellow drum has reached the end of its life.On this machine,it is not as simple to replace the drum unit as it could or should be.Newer machines are far easier to perform a drum replacement.I would have to recommend a trained technician to perform this procedure.
Apr 21, 2010 | Canon Office Equipment & Supplies
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Oct 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
426 people viewed this question
k24674
jasbo
jasbo
