Question about RCA R52WM24 52" HDTV Projection Television
3 colors dont line up how do we fix it - RCA R52WM24 52" HDTV Projection Television
  • RCA Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.The tv convergence board,have dead 2 STK convergence ICS and some or all it resistors,must be replaced these parts to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 06, 2010
My hp laptop screen has color lines after got hit by a ball,how I can fix it?
I dont believe that can be fixed, once you damage the screen, it will remain a damaged screen, sorry
Mar 11, 2013 | Computers & Internet
My 52.inch projection t.v.is out of focus and colors are out lining eachother .thiers so many adjustment. dont no wich one to turn to fix problem.i need owners manual or guide
When doing convergence you start with number 1 x and move to all odd numbers, then you go back and fix the even number. You have to do this until all of the x's are lined up with all the colors.
May 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Env2 doesnt work
dont sit on your phone buy protcetive case for the phone model and be more carefull and dont trom throw the thing it wiil not help fix the problem k
Aug 27, 2009 | Samsung SGH-E900 Cellular Phone
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Colors dont line up and green is "dancing" all over screen
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Cant fix the color
Hi, first thing you need to do is re-post with the model number of your set, sounds like convergence has failed and if so you WILL NEED the original remote and a pair of convergence IC`s, post your model number and I will look up the part numbers for you,
video-tek
Feb 11, 2009 | Samsung Televison & Video
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
Blue line down monitor screen of laptop
I have had the same problem
This happens from overheating or from physically abusing the screen
I have an acer, which can take a lot of punishment, but i throw it around and keep it on 24/7 until it gets so hot the plastic starts to smell and melt
Awesome computer, it still works very well for the price (500$)
It developed blue lines on the screen lately and i know from previous experience acer will replace your screen as this may be a factory problem
If you're a freak like me who runs his computer all the time though, they aren't going to listen to you for one second and you have to deal with it
A) Dont use your computer as much (that sometimes fixes it)
B) Buy a better cooling deck
C) Dont abuse the screen (any bending or even the slightest tap can kill it)
D) If the problem doesnt go away, make peace with it and get used to it
E) Replace the screen (i dont want to, so now i have kewl blue lines on my screen)
Apr 06, 2008 | Computers & Internet
DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Mar 31, 2008 | Canon DR-5010C Path-Through Scanner
SCREEN HAS SEVERAL LINES RUNNING THRU IT
its your lcd that needs to be fixed. you probably dropped it or bumped it pretty hard, loosen the connection. hopefully you dont have to replace your lcd.
Jan 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
