Question about GE Dishwashers
OUR DISHWASHER WILL NOT TURN ON. SEEMS THAT IT IS NOT GETTING POWWER. THE BREAKER IS NOT TRIPPED, IT IS PLUGGED IN, THE PLUG IN OUT LET IS NOT THE PROBLEM EIGHTER. IS THERE A RESET BUTTON ON THE UNIT? HERE ARE THE SPECS. GE MODEL#PWD7550J01SS. IT HAS NEVER GIVEN US ANY PROBLEMS BEFORE. HHMM?
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 06, 2010
My kitchen aid dishwasher is 1 years old and suddenly today it does not work.checked the breaker it's fine.what may be the problem
Make sure the unit is plugged into the outlet under the sink. sometimes when moving things around under the sink, the plug may have come out of the socket in the wall. If that is ok, then you will need to make sure the D/W is getting power. You can use a multi-meter or small plug-in checker that lights up when inserted into the receptacle or outlet to check for power, or have a qualified electrician check for you. Also, just because a breaker does not look like it is tripped, doesn't mean its not. Sometimes that also has to be checked to verify it still has power. Most have to be fully turned off, then back on to be sure it has reset. One more thing to check would be to see if the dishwasher is connected to a GFCI as that may have tripped.
Dec 12, 2015 | Dishwashers
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
My dishwasher seems to not be getting any power and no lights are lighting up. It is still plugged in and I already tried resetting breaker. Any suggestions?
HI. Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything checks out ok with the above suggestion, the main control sector(timer or control board), will be the culprit.
The control sector must be replaced, in this case.
Dec 11, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dishwasher quit working
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 11, 2009 | Whirlpool Dishwashers
Dishwasher will not turn on
Bruce, It would be great to know the model number of your your Kenmore Ultra wash dishwasher, please look on the right hand side of the door for a model/serial number if possible.
First steps: With no power, please check how the dishwasher gets power. If it is plugged in to an outlet under the sink, please confirm that it is plugged in fully. If that does not fix the problem and if it is plugged in, remove the dishwasher plug and plug in any lamp or small appliance and make sure it turns on.
If no power at the outlet, check the house circuit box for a tripped breaker/blown fuse. Also, check if any of the outlets have GFI (Ground Fault Interupt) circuit protection. Reset that outlet (even if it is not not the same outlet as the dishwasher is plugged in to.
Next steps: If the dishwasher is connected to a live circuit but still does not work, a component in the dishwasher has probably failed and a service call is in order. Or replacement of the dishwasher, depending on its age.
Please accept this solution soon after walking through the steps - or add a comment with an update and I will try to help more.
Mar 28, 2009 | Dishwashers
Ran dishwasher, we to work, came home, no power, water in bottom. Breaker is not tripped, power to rest of kitchen
Although breaker has not tripped it is still worth changing the fuse in the dishwasher plug.
Nothing to lose for a few pennies.
Feb 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Westinghhouse 907 dishwasher Sydney Australia
Nov 03, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
62 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
