Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Not making ice. Water dispenser works and water inlet connection is good. Signal arm is down.
  • 49 Answers
There's nothing left that can be wrong aside from the ice maker. Is there ice in the ice maker now that won't come out? It could either be the motor out or there is a small chance that the ice is stuck and won't let the motor push it out. It would probably cost just as much to replace the ice maker as it would to have someone repair it.
Posted on Oct 06, 2010
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Ice machine not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
  1. Dispenser switch
  1. Door switch
  1. Feeler arm
  1. Ice maker heater
Aug 16, 2014 | GE GSS22JER Side by Side Refrigerator
Ice maker not working on Frigidaire frs26kr4a
Good Morning Friend,
I understand that the ice maker is not working on your Frigidaire refrigerator, model# FRS26KR4A. First, make sure the wire signal arm is in the down or on position. Secondly, make sure your household water line is open. Thirdly, make sure your freezer is cold enough to keep items frozen. Fourthly, check the saddle valve, if there is one, to make sure it is not clogged or restricted by any foreign material. Lastly, Check to see if the water dispenser is dispensing water. If no water is being dispensed, the water filter could possibly be clogged and would need to be replaced. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FRS26KR4A Side by Side...
Ice maker quit making ice how to find problem
I understand that your Frigidaire refrigerator, model# FRS26R4A, stopped making ice. Here are a couple of suggestions you may try, to get your ice maker to produce ice.
    1)Make sure that the wire signal arm, inside the bucket area, is in the down or ON position.
    2)Make sure your household water line valve is open and on.
    3)Make sure your freezer is cold enough.
    4)Make sure the water dispenser is dispensing water. If not, the ice & water filter cartridge is clogged or restricted by foreign material, and must be replaced.
    I hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FRS26R4A Side by Side...
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Whirlpool Refrigerators
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
It makes no ice cubes, but water still comes through door dispenser. Why? There appears to be no water getting to the ice making mechanism, however water is still coming out the door dispenser.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Electrolux will not make ice. the water will dispense
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
413 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
