Back to:
Tags:
Toshiba 42H81 42 in. Rear Projection Television
42H81 fuse follow up (by 2 users)
posted by jstiene on May 28, 2008
Ok...Thanks for your quick response..I just ran out to a local repair shop and grabbed a couple micro fuses a I am good o go..,I do have a couple order quick questions if you have thetime.
1.) F850 blew but F851 did not after I replaced both. Is it possible that D851 is bad? I am in the process of resoldering all jumpers as you have noted previously in other posts..hopefully that caused F850 to blow again..
2.) I saw a note the C809 and C810 neex to have negative terminals resoldered...I am having trouble locating these capacitors in my Toshiba 42H81...do you know where they are located?
3.) other than replacing the (2) Conv IC's (already did) and resoldering all jumpers, anything else I should be focusing on? All resistors in Conv IC circuit seem ok btw..
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 15, 2008
As soon as i turn it on it turns off. what is a c810 or a c809
Can you Help with these Projection Televisions problems?
Toshiba 42H81 42 in. Rear Projection...
I am having a problem manually converging my tv. the touch...
Had Convergence problem, replaced the STK 392-110's on my...
I have lost the users manual and cannot find where to get...
i need to know the number/letter locations of the...
I don't how this happened but the question writen under my...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
