Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
My surround sound shut off and sound went to tv as it's output source
    Problem Solver:
  • 5 Answers
Try unplugging it and pluggin it back in. and make sure no wires are touching that would make it shut down.
Posted on Oct 06, 2010
How do u get surround sound from a 32 inch apex tv to a Sony receiver
Connect basic audio output from your Apex TV to audio input of your Sony receiver. The receiver is the source of surround sound.
Dec 30, 2016 | Sony Televison & Video
Have no sound on my surround sound sony
Could be a number of things try each and test!
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode. IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
Dec 21, 2014 | Sony Audio Players & Recorders
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
How do i connect my hitachi tv to my surround sound system i tried red and whit cables as thats all i can connect to my surround sound system bit it does not work
The red and white RCA cords from the TV 's AUDIO OUTPUT must be connected to the INPUT of the surround system. You can counter check the input of the surround with another input like a DVD/VCR and if this works the TV output must be absent. Check if the connection was given to the OUTPUT and not to the input.
If not there is fault in the preamp output of the TV sound amplifer. You need to use a signal source to confirm. If not the earphone output can be used with a resisitor network for impedance compensation.
Sep 20, 2011 | Hitachi Televison & Video
Want to use all 5 speakers on surround sound yamaha htr-6230 on tv programs. how set up?
Depends on the audio source for your TV sound. If it's a digital cable box, run a coaxial or optical cable from it to an available digital input, assign it as "TV" and you're done; or if the cable box has 5.1 analog outputs, usethose to the Multi Ch imputs.
If your TV sound source is only RCA cables (stereo) you're stuck with DSP surround modes.
Dec 27, 2009 | Audio Players & Recorders
Need to know how to make the surround sound work through regular T.V. with durabrand surround HT-3915
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
Jerry G.
Feb 22, 2009 | Durabrand HT-3915 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
106 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
