Question about Eureka Atlantis 2590A Wet/Dry Vacuum
The handle release button is broken/ the handle will not fold
  • 377 Answers
If you go to this URL:
http://www.ereplacementparts.com/eureka-2590a-carpet-cleaner-parts-c-108750_109432_109471.html
you should be able to identify the part and order it as well.
If you find this solution to be helpful, I would appreciate a Thumbs Up rating from you.
Be well, Paul
Posted on Oct 06, 2010
How to change the release pedal on Hoover SteamVac F5914-900 SpinScrub
99 out of 100 times it's not the handle release pedal that's broken. it's the knob on the rear housing broken off. You will have to replace the rear housing. Take it to a local vac shop for repair.
May 07, 2017 | Hoover Vacuums
Broken handle release pedal
Definitely. Just find your local authorized BEAM dealer and they will sort it for you. Sorry, I don't know where you are so I can't find you a dealer but BEAM's website has a dealer locator.
Dec 24, 2013 | Beam Q power Brush Q100
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
There does not seem to be a handle release button on my bissell shampooer and I can't get the handle to release. Model 08239 C 082390
Seems like the on/off switch is at the bottom of the handle on one side, and the handle release is on the other side. Both are foot switches; that is to say that they're operated with your foot.
--W/D--
Jan 20, 2011 | Bissell Vacuums
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
How do you get the water tank out to fill on the bissell pro-heat
release the handle until it sits all the way flat. At the top of the water tank there is a folded down gray handle, lift that up and then pull up on the handle and it should come straight up. Then you need to push that gray handle all the way forward so that the lid will pull up, and you then pour the clean water into the small round opening in the top of the open tank.
Jun 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Whispertone powerhead handle release replacement
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Most times they don't break, it is the 2 screw holes at the back that back and the top will raise up from the base. If this is the case, remove the 2 screws and install longer ones with a flat washer on them to fashen down the top. But first the top will have to be removed to put the handle release in the right spot. You would probably look at around $60 to repair, unless the top needs replaecment, then it would be more parts.
Apr 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Broken Handle Release Pedal
what is part number for broken pedal release
Oct 29, 2007 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Eureka Atlantis 2590A Wet/Dry Vacuum Logo
61 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
