Question about Sierra Wireless Computers & Internet
My computer states that there is not a network. Sierra Wireless AC5950 1xEV-DO Network Adapter system cannot find the file specified Any help will be greatly appriciated! Thank you, Lori
  • Sierra Wireless Master
  • 7,733 Answers
Download your driver->link.
Posted on Oct 06, 2010
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
I need help to get my sons xbox working with a wireless adapter
Hi Joanne,
If the wireless adaptor is the one shown in your picture, you simply plug it in the back in the USB slot.
Configure your wireless settings loadTOCNode(2, 'whattotry');
  1. Go to My Xbox, and then select System Settings.
  6. Select your wireless network name. If your wireless network is not listed, select Specify Unlisted Network and enter your wireless network name.
  8. Press B on your controller to retest your connection.
Kind regards
m-press.biz
Jun 15, 2010 | Microsoft Wireless Network Adapter Xbox...
Brand new aspire 5732z laptop comes up with code 31 fault on virtual wifi miniport adaptor says it has driver fault,what can I do
The Microsoft virtual wifi miniport adapter is a new feature in Windows 7, Wireless Hosted Network:
About the Wireless Hosted Network
This device is just a virtual device and it should not affect connecting the wireless network with the physical wireless adapter.
Hence, I’d suggest you to uninstall and re-install only the wireless network adapter drivers from Device manager and check if that fixes the issue.
Before uninstalling the drivers from the device manager, make sure you have a backup of the installation files.
It’s a good idea to create a restore point before uninstalling the drivers. A restore point is a representation of a stored state of your computer's system files. You can use a restore point to restore your computer's system files to an earlier point in time. Restore points are automatically created by System Restore weekly and when System Restore detects the beginning of a change to your computer, such as when you install a program or a driver.
Create a restore point
http://windows.microsoft.com/en-US/windows7/Create-a-restore-point
Visit the manufacturer’s website, download the latest wireless drivers and save it on your hard disk.
To uninstall the wireless connection from Device Manager,
1. Click Start, type Device Manager in the Start search box and hit Enter.
2. Locate Network adapters and expand the same.
3. Select the wireless connection, right-click and select Uninstall.
4. Restart the computer, if prompted.
Drivers should get installed automatically after restarting the computer.
Now, you may install the latest wireless drivers and check if that fixes the issue.
Hope this helps
Apr 20, 2010 | eMachines eMD620-5133 Notebook
XBOX 360 WIRELESS ADAPTER
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
I'm not able to connect my Lenovo laptop with my Linksys WRt54G wireless router. The Access Connections software on the laptop gives the following three (3) error messages: "Verify that the encryption...
Temporarily connect to the router with a cable and reconfigure it to use a different wireless channel. While you're there, this is a good time to change your security mode - WEP is dangerously weak and you should switch to WPA unless you have a very good reason not to.
If all else fails, there's a reset switch (hidden inside a hole) on the back of the router.
Oct 12, 2009 | Linksys Wireless-G WRT54G Router
C:\program files\belkin\belkin wireless netwrok
Find the Version Number on the adapter
Goto
http://en-us-support.belkin.com/app/answers/detail/a_id/2752/kw/F6D4050/r_id/166
And Reinstall the Drivers
Apr 19, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Network adapter
1) The first step you can try by checking from device manager whether its showing the device over there or not. Just click on Start and type there "devmgmt.msc". Under network adapters or in other devices if you are able to see any device which state as network adapter it means its getting detected. If not!!!
2) Check by changing the slot of the adapter and insert it any other slot in your computer..
3) If it still doesnt work then if posibble can check this adapter with any other computer as well
May 31, 2008 | ASUS PCI-L3C920 Network Adapter
Computers & Internet Logo
Top Sierra Wireless Computers & Internet Experts
Jerry Umali
William Covington
Level 1 Expert
Are you a Sierra Wireless Computer and Internet Expert? Answer questions, earn points and help others
