Question about GE Dryers
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in particular) is super hot!! When my husband checked it, it appeared to be spinning and blowing hot air, but the clothes aren't drying. There's tons of moisture beading up on the door and dripping off the door when we open it. We need our dryer to be working!! :(
  • 49 Answers
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Posted on Oct 06, 2010
Water coming out of the back of the dryer
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
Jan 13, 2015 | Maytag Neptune MAH5500B Front Load Washer
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of...
okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Apr 03, 2008 | Dryers
Dryers Logo
124 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
