Question about Kenmore 30169 Electric Single Oven
When i turn on the stove it beeps and says F3. What does that mean
  • 2,382 Answers
Hi, what you have is a fried relay on the board. the contacts are stuck. Find the board and yank out the wire marked Br1 and see if the broiler shuts down. Do your findings while the machine is without power amigo. More than likely you needs an expensive new control board. You could just remove and tape off one of the broiler wires if the bake still works.....
Posted on Oct 06, 2010
F3 code
I don't think in is unsafe to operate. I worked with boilers that used igniters and a temperature sensors. Usually what these codes mean is (simply error codes ) to guide you which part/s does not function or respond correctly or within a certain time in seconds and brings up this code, but if you get it to ignite, use it like that until you can get someone to do some maintenance on it. Just remember, if your heat is not at the correct temperature, your igniter will fire, but will not be able to ignite the flame.
Meybe lookat this video will make you understand better.
Apr 29, 2014 | Ovens
F3
F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
Jan 24, 2012 | Maytag Ovens
My wife used the self clean feature on our gas stove an now it keep beeping and showing the f3 code how do i make it stop cause the stove wont even turn on
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 22, 2010 | Ovens
How do i unlock my stove, it is a ceran hotpoint stove. while cleaning it locked and started beeping a flashing F3 . what can i do.
f3 fault code / open oven temperature sensor .) this sensor tell the E O C ( clock ) oven tempts . it will have to be replaced .. ther could be other problems with oven but first things first replace sensor and see how it works .. **** . hop this will help .
Dec 04, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
MY STOVE
hi thanks for the question .F3 on a Frigidaire stove means that the oven sensor is open that's the part in the oven to the left and top it looks like a pencil replace part from the back of the stove but with 1 screw holding the sensor replace BUT power off please thanks the appliance doc
Sep 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kenmore 30169 Electric Single Oven Logo
55 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
