Question about Brother IntelliFAX 2800 Laser Fax
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
    Scholar:
  • 159 Answers
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Posted on Oct 06, 2010
Error code "change drum soon
This is NOT an error code...the machine is simply telling you that it has run/printed a certain number of pages and it will soon be time to replace the drum.
Oct 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Print out of faxed copies are too dark AFTER the first 3
You need a new drum unit. The built-in cleaning blade has worn out.
Apr 11, 2010 | Brother IntelliFAX 2800 Laser Fax
How to reset brother 2850 fax drum
Try opening the front and press clear it should say replace drum press 1 for yes it should then reset,
Oct 15, 2009 | Brother IntelliFAX 2800 Laser Fax
Horizontal lines and tones specks around text
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
Jun 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Change drum soon will not clear after new drum inserted
Reset of the drum counter
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Jun 10, 2008 | Brother IntelliFAX 2800 Laser Fax
"CHANGE DRUM SOON"
To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 4100 - drum needs replacing
The drum is what the toner goes into. DR-350 or a similar #. You can get at staples or office max.
Apr 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Copied pages are all black
Is is a lower end product for light duty use. You can try a new genuine OEM drum and or toner, but buying them both would cost as much as a new 2800. Can you print a internal report OK?If so, then your scanner is defective. A common problem with 2800,s
Mar 24, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
754 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
