Question about Kenmore 60172 Electric Commercial Dryer
Push button and motor just buzzes. I replaced the thermostat & cutoff.
  • 49 Answers
If the motor is buzzing when you push the start button then it is almost certainly a bad motor. There is a small chance that the tub is in a bind from a stuck roller or other problem but this can be confirmed by inspecting those and trying to start the dryer with the belt off.
Cheers
Posted on Oct 06, 2010
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Amana dryer mod. ned5100tq1 will not start. It only buzzes when i push the start button
Does it buzz or growl? Reach inside and turn the dryer by hand. Is the drum hard to turn? Might be a bad roller or possibly something stuck in the filter chute and lodged against the blower. I worked on a dryer exactly like yours and made a video. If the blower is clean and clear of obstacles and the wheels are fine then the motor needs to be replaced which is easy to do. The hardest part is getting the blower wheel off the motor (backward threads on it) Motor replacement video:
Manual and more is on my BLOG PAGE
Feb 24, 2013 | Amana Dryers
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
When you push the button to start the dryer, all it does is buzz and nothing happens
next time send the model number and brand name,all dryers are not the same!it sounds like a bad motor.open the door,push the door switch in with one hand and with the other spin the drum,while you're spinning the drum have someone push the start button,if the motor starts you'll know the motor is bad but it might run for a while before it does this again or it will do it every time but either way the motor should be changed,also on some dryers if the belt broke it will buzz like when the dryer is down but if yours is more like a humming sound like power is going to the motor but it won't run then it's the motor.
Apr 24, 2011 | Dryers
Push start button and get electric buzz/humm but does not start. a month ago we had noticed a slight electric hot smell when it still ran, but no real smell lately. Is it the start capicitor or the...
Hello & Welcome to FixYa
The smell is from the motor that is bad and needs replacement, the hum/buzz sound itself indicates that the problem is with the motor, don't think it is the start capacitor. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | LG DLE5977 Electric Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Kenmore Elec. Dryer Model 66912 (1996)
The problem is the motor switch . Try spinning the drum with the door switch held in and pressing the start button all at the same time .If the problem is lint in the switch that might be all you have to do . If that don't work you will need to replace the motor and no special tool required. I can walk you through it.
Dec 12, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Kenmore electric dryer model # 87670100
The motor is weak and needs replaced, don't hold the start button too long or you may smoke the motor's thermal protection and it could get smokey and stinky. Make sure you can get the blower wheel off before you make a run for parts, sometimes you have to break them off the shaft. : (
Sep 17, 2008 | Dryers
Kenmore 60172 Electric Commercial Dryer Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
