Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
I purchased a Dyson DC05 cleaner from a garage sale.The suction is great,however I noticed that the debris does not swirl around in the cylinder when I am vacuuming.I think the suction could be even better. Has a part possibly burnt out? I have cleaned both the foam and Hepa filters, what else can I try?
  • 78 Answers
Hi there VacuumGuru from Vacuumspot.com.au here. You will find there are 2 reasons will not spin in a dyson DC05. 1 is that it is missing one of the 2 parts in the dust container, there should be an upside down funnel in there and a rubber boot on it. Without those dust just goes either to the bottom of the bin or to the filter. The 2nd cause is that even though the filters have been cleaned they are simply too old. When you hold the washable filter (the one with the plastic outer and the foam insert) up to the light and take out the foam bit you should be able to see light through the filter. If not you are probably only running on maybe 80% suction which still works but isn't as good as it could be.
The filters are available here if you need them.
Hope this helps! :)
Posted on Oct 17, 2010
SOURCE:
Weak suction on dyson dc05. The suction is not as good as usual
Hi its Darran at Dyson.
Try washing your pre filter and checking the machine through for a blockage. These are the most likely causes.
A full blockage procedure and filter washing instructions can be found at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service
Feb 16, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Loss of suction!
you can tell if the vacuum is not run properly by the sound and no suction. check all the hoses and line, more likely is clog up and it the only reason why any vacuum cleaner seem to run louder and run hot due to the line is clog. check the hose line at the bottom of the base where the suction located with the pickup brush; it tend to get clog at the base.
Nov 23, 2009 | Dyson Vacuums
My DC05 Dyson suction has stopped...there are no blockages, the seals are good, there seems to be more suction coming from a yellow box which is situated at the top of the removable cannister. There is...
My Dyson had exactly the same problem. I found the problem was caused by a blockage in the hose. Take the hose out where it joins the cleaner (it will come out if you pull it downwards gently) and take the hose out of the handle by squeezing the yellow buttons on either side. I pushed a rubber alkathene pipe down and found a piece of plastic was blocking it even though at first I was sure it wasn't blocked.
Jan 11, 2009 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC05
Hi
try this site http://dysonmanuals.llc.nu/
It has service manuals for the DC05.
Jul 28, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC05 vaccuum cleaner
I pried the wheels off with a couple of tyre levers.
Under the wheels are a couple of Torx screws.
Undo these and the casing comes apart.
Jul 15, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson Vaccuum Cleaner
Hi.
If you need to strip the Dc05 right down try this site http://dysonmanuals.llc.nu/
Has manuals on how to strip machine down.
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Dyson lsoing suction
Hi.
Turn the 3 plstic screws under the machine to unlock position & remove sole plate,
You can now see if belt has snapped & replace it.
http://dysonmanuals.inc.io/
Chris.
Nov 21, 2007 | Vacuums
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
173 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
