Question about Olevia LT32HVE 32 in. LCD Television
Cc button i have olevia 32 series 5 i bring up the box with closed caption on it and i do not see a turn off what do i do
  • pmullinax Sep 10, 2008
    I have the same problem. The CC button on the remote does not work. I get to the setup CC menu, but I can't figure out how to turn it off.
I tried pressing the CC button "cc off" and it doesn't come off. Help, that darn cc is annoying!
Posted on Aug 01, 2008
  • 979 Answers
Press "cc" again, and that should do the trick...accordianman
Posted on Jul 01, 2008
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
Black box popping up on screen
Your closed caption is turned on. The box is a text box. Closed captioning has CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 AND TEXT4 modes. Each mode has it's own use or screen position. If you have a CC button on your remote, press it until CC is OFF. You may need to go into the TV menu to do this, I'm not certain. At any rate, with a little investigation, you should find the closed captioning feature and discover how to shut it off. Best wishes.
Apr 16, 2010 | Olevia LT42HVi 42 in. LCD Television
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
Apr 04, 2010 | Olevia 237T 37 in. LCD TV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Black box appears on every channel
Hi:
This black box is the close caption box, you must of turned the feature on. Go into you menu setup screen and under CC option turn off Close Captoin, or you may have a CC button on your remote that you hit by mistake, try hitting this button until it says Close Caption off.
Dec 24, 2009 | JVC AV-32D305 32" TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
How to remove closed captioning
you can either turn it off in the TVs main menu or check for a CC button on your remote.
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
27 INCH OLEVIA LCD FLATSCREEN
Access the TV's menu by pressing the "menu" button on the remote. Look for "Captioning" or if not on the screen try "set-up" or "audio" all the while looking for "CC", "Caption" or "Closed Caption".
When you find it, turn it off.
Apr 06, 2008 | Televison & Video
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
I had the same problem....
The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Olevia LT32HVE 32 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
