Question about HP Pavilion a420n PC Desktop
When i power on the desktop, the lights on the keyboard, and mouse flash once then go away. the tower is on, the disc drives eject, the light near the power plug is green, and the power button is blue. but nothing comes on the screen and the mouse and keyboard lights don't turn on.
  • HP Master
  • 11,800 Answers
Sorry but the chipset on the motherboard failed, you will have to replace the board.
Posted on Oct 06, 2010
Flashing orange light
PC may be sleep mode, tap keyboard or move mouse, may be a sleep button on the keyboard. Is the light on the tower or the screen? Hope this helps.
Feb 17, 2013 | HP Pavilion a1610n PC Desktop
When pushing the power button on the tower, the power lights on the tower, mouse, and keyboard continually flash, and the computer does not actually turn on. The only way for the flashing to stop is by...
The power supply is receiving power from the source but is unable to properly distribute it to the components. This means that either your power supply is bad or the motherboard. Try removing all devices attached to your computer and check your USB ports to see if they are damaged.
Jan 09, 2011 | Dell Dimension 2400 PC Desktop
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Disk won't eject on my iMac
Ok, I assume you have hit the eject button on the keyboard. Try dragging the CD icon on the desktop to the trash can. If that doesn't work, Shut down the computer and start up while holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Another option is to open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder. Another option is to Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Lastly if your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button. One of these should work.
Sep 03, 2009 | Apple Mac mini G4 Desktop
My disk drive is stuck and won't open
Try first a soft eject: Go to my computer, Point the CD-ROM drive, right click mouse button, and choose eject. If that dose not work, examine the face of the drive and look for a small pin hole. Insert a blunt paper clip in the pin hole and press gently. The drive should open.
Hope it helps.
Aug 29, 2009 | Sony VAIO PCV-V200G PC Desktop
Mouse and Keyboard not functioning!
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Aug 16, 2008 | Logitech Cordless Desktop EX110
No mouse,no keyboard, and no monitor?
try to connect it with other keyboard,mouse and monitor....if they will run, the keyboard,mouse and monitor may be defective or damaged..but if they did not run properly,,
maybe somethings wrong wit your unit...
try to connect it first and see whats the result...
please tell me what are the results...
you may post it here...
chaw
Jun 17, 2008 | Computers & Internet
HP Pavilion a420n PC Desktop Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
