HotPoint WF640 Aquarius Washing Machine error F10
Hi my washing Machine is stopping a few minutes into its cycle with an F10 error. I have looked on the support sites and it is suggested that there is a problem with the intake or exhale of water from the machine. This is strange since the machine takes in water and will empty. Can you help?
  • 1 more comment
  • ardgay Sep 06, 2008
    I too have Hotpoint Aquarius WF640 showing F10 error code-any ideas
  • Anonymous Sep 27, 2008
    i have the same problem..i even called in someone to have a look at it and he didn't find anything wrong with it...wish hotpoint would explain this error and how to solve it
  • Anonymous Feb 18, 2009
    hotpoint aquarius wd640 error f-10
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Posted on May 27, 2009
  • 4889 Answers
SOURCE: Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Posted on Nov 03, 2007
  • 14 Answers
SOURCE: Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right will need to repeat approximately every three months
Posted on Dec 30, 2007
  • 86 Answers
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
Posted on Dec 30, 2008
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
Hotpoint washing machine faults
Nicky, try a dry run without a load. Also check if moving to different levels gives you any reading. If not, you have narrowed down where the problem is.
Mar 01, 2014 | Washing Machines
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
746 people viewed this question
Top Washing Machines Experts
