Hello I have a fault coade coming up on a cassette split system Model number 40KQV130A Serial number 05AQ129878. Fault is 1 x flash amber led followed by 5 flashes of green led. Indoor fan motor shuts down. Can you help. Regards Adam Kenny
  • arktic437 Oct 06, 2010
    Exactly what I needed.Thankyou
  • 3,247 Answers
Please confirm if this is a carrier brand aircon. Refer page 53 of the attached manual.
Each LED position and how many time it flashes gives a fault code. Most likely the observation you have means code 15. Go to page 59 for the actual diagnostic. See page 35 for location of the TCJ coi sensor connector on the circuit board inside the cassette. The specifications of the sensor are provided on page 36.
The manual is very detailed and should help you replace the TCJ sensor or the board as necessary.
Please rate the solution to help fixya serve you better in future.
Posted on Oct 06, 2010
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Led green flashing power amber
Amber lit when there is hardware fault within server. Open Light Path Diagnostic panel and see server part that's having amber.
Oct 21, 2013 | IBM System x3650 Server
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Is there an ALDL port on a legend ...to plug in a scan tool
There is a connector but it is not like the connector used in the newer 1996 OBD2 cars, your year uses OBD1, here is how you check for codes in this car.
Acura OBD1 Codes Retrieval
Acura vehicles 1986-95 obd1 code retrieval
There are a few different ways to retrieve the codes for "check engine light" for Acura vehicles. One method is to use a led light (sometimes 2 led lights) on the computer or controller box itself. If it has 2 led lights, the color is red and amber. The red is used for flashing the codes whereas the amber is used for adjustment. If you have only a single led light indicator, then that is used for flashing the code.
The controller box can be found by lifting the carpet of the passenger side front foot well or floorboard. You can see the led lights without removing the controller. On other models, you can find the controller under the driver or passenger front seat.
The second way to get the code is using a jumper wire on the diagnostic connector located on the kick panel at the front passenger side. You then watch the codes being flashed at the dash panel after you turn the key on. To read the code being flashed is easy. Example: Code 23 is 2 long flashes followed by 3 short flashes. A longer pause separates the next code that follows.
Here are Acura vehicles 1986-95 general codes:
Code 0 Electronic control unit (ecu)
Code 1 02 (oxygen) sensor
Code 3 and 5 map sensor
Code 4 Crank angle sensor
Code 6 Coolant temperature sensor
Code 7 Throttle angle sensor
Code 8 Crank angle sensor (TDC)
Code 9 Crank angle sensor (CLY)
Code 10 Intake air temperature sensor
Code 12 EGR system fault
Code 13 Atmospheric pressure sensor
Code 14 Electronic air control valve
Code 15 Ignition output signal
Code 16 Fuel injector fault
Code 17 Vehicle speed sensor
Code 21 Spool solenoid valve
Code 22 Valve timing oil pressure switch fault
Code 23 Knock sensor
Code 41 Oxygen sensor heater fault
Code 43 Fuel supply system
Nov 30, 2010 | 1990 Acura Legend
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Amber light on front of laptop flashes.
The left led of is amber" is that fault exist on it?"
If you don't experience any network connectivity problems on that NIC, then you should not worry about this. This is a normal condition.
Apr 06, 2009 | HP ProLiant DL380 G4 Server
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
