Question about Dryers
My dryer smells like it is on fire. - Dryers
  • Dryers Master
  • 3,740 Answers
This is a sure sign you have airflow problems in your dryer.
1. Check all of the ducting from the lint filter.... all the way THROUGH the outside wall for signs of blockage / ANY lint build up.
2. Check airflow at the dryer exit by removing the duct connection. The airflow should push a relaxed hand away from the dryer vent connection.
a. If it does not do this the problem can be
1) Excessive lint inside the dryer ducting
2) Lint filter clogged with dryer fabric sheet material (wash with vinegar and water then soap and water)
3) Area around lint filter blocked / restricted by lint
4). Broken blower wheel.
Until you resolve this problem: I highly recommend you stop using your dryer as it really can catch fire.
Thanks for choosing FixYa
Kelly
Posted on Oct 06, 2010
My hotpoint tumble dryer almost caught on fire the house was full of smoke can l claim
Only if you can prove that the fire/smoke was caused by a machine defect and not a lack of cleaning the unit out once in awhile.
Jun 20, 2016 | Hotpoint Dryers
My BaByliss blow dryer smells like burnt when I turn it on and I seen like a spark is it going to work anymore
DRYER SMELLS LIKE BURNING:
Answer:First, Stop using your dryer until this problem is resolved. This is a fire hazard and could cause a fire.
Your issue is more than likely alint build up problem. The lint that comes off of your clothes as you dry them becomes trapped in the dryer itself and in the venting duct that connects from the back of the dryer to the wall.
The first thing to do is todisconnect powerby unplugging the dryer cord from the wall. Slide the dryer away from the wall slowly.Remove the hose ductthat attaches to the back of the dryer. Look inside the hose duct and if you see heavy lint build up, that is most likely your problem. If you have a shop vac vacuum or similar, use the long wand attachment tovacuum out the lintthat is in the duct. The best way to do this is to completely remove the vent duct from the wall and dryer.Vacuum the inside of the ductto clean it out. Alsovacuum in the vent hole in the wallwhere the duct attaches to the wall and remove any lint that may be blocking air flow. Put everything back together and test your dryer to see if the burning smell has been resolved.
NOTE: There may be heavy build up of lint deep in the wall. You can purchase aDryer Vent Cleaning Kitthat may make your job of cleaning the vent much easier. However, it may be best to call a Dryer Vent Cleaning Company as they have the equipment that is needed to remove all lint in the wall that could cause a fire. We know everyone wants to save money and "do it yourself" but when it comes to safety, money should not be an issue.
If the burning smell is still present, you cantake the dryer apartandtry vacuuming out any lintthat may be built up on the inside of the dryer. Do a search for your dryer model name and number onGoogleto see how your particular dryer model is disassembled. If you are not comfortable taking your dryer apart then it is advised to call an appliance repair company as your issue can cause a fire.
There are other reasons for your dryer to have a burning smell. There could be an electrical issue inside your dryer. This may mean that a certain part or electrical board is going bad or is bad. Another common reason for this issue is something is near the heating element inside the dryer and causing the burning smell. If you have an older clothes dryer, it may be possible that the components are past its life span and it is time to purchase a new dryer. If you want your dryer to be looked at by a professional, it may be time to call an appliance repair company to come out and check your dryer.
There are plenty of videos that can help you to determine what may be wrong with your dryer. There are a few videos below that may assist you with troubleshooting and disassembling your dryer.
The belt
In some dryers, a belt turns the drum. This belt can slip off, which can cause it to start melting. Because it is usually made of rubber, it will then produce a very strong, unpleasant burning odor. If your drum is not turning smoothly or properly, and you notice a bad burning smell, your belt is probably damaged.
THE MOTOR
Dryers have motors, and as they age, they can burn out just like any other motor. This causes a very strong burning smell, and your dryer will either not run at all, or it will run poorly and with a lot of noise.
Read more :http://www.ehow.com/list_7173741_causes-burning-smell-dryer.html
Causes of Burning Smell in Your Dryer eHow
Apr 22, 2016 | BaByliss Dryers
Dryer smelled like something was burning and turned off. What could it be ?
Need to have your Dryers Cabinet area cleaned like Now having a Possible Dryer Fire
Sep 15, 2014 | Kenmore Whirlpool Dryer Gew9868kq0 Light...
I have an asko dryer T712C which after 5 years has a burning smell and the sheets that have been in smell of smoke
be careful as this sounds like a big fire hazard. Could be aa faulty thermal cut-off or lint buildup trying to catch on fire.
Aug 05, 2012 | Dryers
My ge stackable smells like it is burning. How do I fix this?
Well, you do not mention which machine causes the smell. My concern is fire hazzard, be sure to check the dryer hose system, and DO NOT USE plactic vent hose, major fire hazzard, they make the same thing in metal and it works better....
Sep 20, 2009 | GE Spacemaker Washer and Dryer Electric...
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Burning smells
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.(this is a fire hazard)
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Jun 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
Burning smell when it is on. Dryer still works
Make sure the duct to outside is not obstructed. Number one starter of fires with dryers.
Apr 15, 2009 | Frigidaire Electric Dryer
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
102 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
