Question about Panasonic PV-DV400 Mini DV Digital Camcorder
How do i get the blue screen to go away when i turn it on?
    Genius:
  • 1,812 Answers
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
All my tv shows a a blue screen nothing else even when I press input
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Televison & Video
Cobra5550 gps screen went blue,reset does nothing.Turn on blue screen,hit power button to turn off,displays/sleepmode/poweroff in seconds.
throw it away. they are to confusing. go buy yourself a road atlas and maybe a few street maps of where you are going and you will be better off. driving 45 years and never got lost.
Jan 26, 2013 | Cobra 5550 Pro 5" Trucker Driver...
My screen has blue and red lines across it. Now the red lines are becoming stronger and the screen flashes red until it turns off. how do i fix this?
This is for if the lines are thin and in the form of an arc across the screen.
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
You see red and blue lines curved across the screen when there is a blank screen
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
I get blue line ine the screen when it balck
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue CRT.
follow the steps below:
Feb 16, 2011 | Sony KP-57WS500 57" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Blue spots on screen
lol. there is a speaker next to it a big speaker. just move it away! lol. the spots will go away.
Jul 14, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
RCA Scenium HDLP61W151yx1
its the color wheel.
Jun 28, 2008 | Televison & Video
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Panasonic PV-DV400 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
