Question about Garmin GPSMAP 2010 Chartplotter
It will not read the bluechart data card. Card loads on other units. Garmin says card reader in unit is probably faulty but they no longer sevice. Where can I get this fixed?
That unit has two data card slots. Does it work in either slot?
Posted on Apr 13, 2011
Have a garmin 62s loaded with the garmin upper midwest anglers fishing guide sd card. IT is enabled but won't appear on the screen of my unit?
You may have a bad SD Card. Put the SD Card in a computer card reader and see if there are any data files on the SD Card. The SD Card may be blank or have corrupted files. Or the card might have just died.
Oct 07, 2014 | Garmin GPSMAP 62s GPS Receiver
I just received a model #441 S from West Marine. My boat is moored in Alburgh, Vermont USA. It's about 1 miles south of the Canadian border. The unit won't show any chart untill about 2-3 miles south of...
You will need to get the Canadian Bluechart Card also. At this time Garmin doesn't pre-load the units with Canadian Charts. Maybe in the future. Here is a link to the card you will need.
Garmin Canadian Bluechart G2 Card
Jul 19, 2010 | Garmin GPS
I tranfert bluechart from my PC using mapsource to
I recommend upgrading your system software to the latest version (5.30),
follow this link for directions and the file's location.
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
Jul 04, 2009 | Garmin GPSMAP 545s GPS Receiver
I have a Garmin 178c map/sounder and it will not load up my BlueChart Data Card. I bought a new card, thinking that would cure my problem, but it didn't. I would love to get your input what steps to take...
I have the same problem. Did you ever figure out why it was not loading? There are no software adjustments to be made. Just plug in the card and wait. It says its reading the card, but never goes any further. Let it 'read the card' for hours with no luck. Help!!!
May 16, 2009 | Garmin GPSMAP 178C GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
Garmin Maps
No, Garmin maps will not work on a Magellan Triton.
Yes, you can install Bluechart and CityNavigator onto one SD card. Inside Mapsource, select the Bluechart maps you want, then switch to CityNavigator and select the maps you want from then, and then send all at once to the GPS unit. If you send Bluechart maps, and then CityNavigator, the CityNavigator will overwrite the Bluecharts. This is why it must be done all in one step.
If this solves your question, please remember to come back and rate the answer.
Apr 21, 2009 | Garmin GPSMAP 76Cx GPS Receiver
Easy Go Golf Cart
Ignitor will cause this problem. The charge capacitor inside the unit is firing once. The Unit is expensive and getting harder to find.
http://www.golfcarcatalog.com/catalog/index.cfm?fuseaction=product&theParentId=698&id=1703
Sep 04, 2008 | Garmin BLUECHART G2 2EU466S GOLFE DU LION...
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
Garmin i2/i3
Either you have a bad micro SD card or you are loading more data than the card can hold.
You will need slightly less than 2GB of memory load load USA and Canada all together at the same time.
You can also try buying an external card reader and instead of loading to the garmin load the map data onto the micro SD card from the reader.
Dec 03, 2007 | Garmin StreetPilot c340 GPS Receiver
Have problems with the loading of the map XPC415S. Australia East coast. Will this map work with this unit?
Any bluechart that has been preloaded on an SD card should work.  Did you purchase your chip with the data preloaded or did you download it yourself?  If you downloaded it yourself, try erasing the sd card, format it, then insert the blank card in the 420 and power it up. This somehow preps the chip for the data download.  Then download the bluechart onto the chip and try again.  There is some ambiguous wording in the download screen that makes it look like some kind of error, try the download anyway and most of the time it will work. After the download is complete it should list the bluechart software version on the screen along with some other software info.  If the operating system software is not v2.5 or higher, you may need to download a software update first.
Oct 25, 2007 | Garmin GPSMAP 420s GPS Receiver
Garmin GPSMAP 2010 Chartplotter Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
