FixYa.com
Tags:
Ovens
Generic problem for all Ovens
Bosch HBN 642 -- single oven cycles and doesn't get...
posted by Constance200 on May 28, 2008
I own a 7-8 year-old Bosch wall mounted single oven, HBN 642 A UC.
Problem 1: in bake convection and regular bake mode, oven would operate fine when used for shorter periods -- up to, say, 40 minutes. When operating for longer (say, 45+ minutes), the unit would stop heating and would not heat up again until completely cooled down. (I.e., the "heat" light would go out, convection fan would stop, no heat to elements, and unit would cool down, regardless of position of control or temp. switch.)
I attempted to troubleshoot by carefully removing and disassembling the "thermometer" and cleaning the contacts. Re-assembled and re-installed.
Problem 2: Now the unit only heats up to, say, 325, then cycles -- heat on, heat off -- every 5-7 seconds when the unit reaches 325. (Yeah, I probably made the situation worse.) Problem exists in both regular and convection mode, except the convection fan cycles as well in convection mode.
Would you recommend a new thermometer? New high temp. sensor? If a new thermometer is needed, do they simply install without any adjustment to the part?
Thanks in advance for your kind assistance.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2008
Not Rated (0)
MARINE0612
Rank:Guru Guru
Rating: 88%, 58 votes
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE JKP15 Electric Single Oven GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... GE JGRS14 Gas Single Oven GE Monogram® ZMC1095BFBB / ZMC1095WFWW Electric Single Oven GE JRP15 Electric Single Oven GE JRS06 Electric Single Oven GE JKP20 Electric Single Oven
Can you Help with these Ovens problems?
Amana AEW4530DDS Electric Single Oven
Old Amana - no manual; can't...
My Mom has an old Amana... Answer This...
Ovens
Neff Oven Fan stalling
Neff double oven U14... The fan... Answer This...
Ovens
Oven is too hot
Hello, We have a Frigidaire... Answer This...
Ovens
Westinghouse freestyle gas oven...
I have a westinghouse freestyle... Answer This...
Whirlpool AKZ159IX Oven
whirlpool oven
After power cut I can not... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
