Question about Cerwin Vega E-76C Center Speaker
Sound on the speaker is very low voices are barely audible. have tried all eq settings but sound remains low please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
Look through your receiver's DSP sound settings. When you locate the volume control for the center channel, adjust it to be in balance with the music and sound FX. Often, I just forget about the DSP and run the sound in stereo with subwoofer. Helps to minimize the different audio mixes between different TV STATIONS AND DVDs.
Posted on Oct 07, 2010
While playing DVDs on my PC I get music and sound effects but no voice or extremly low voice. If I crank up speakers and PC volume to 100% I can barely hear vocals and they sound like they are in a 50...
1) Could be your speaker connections and balance settings.
2) Could be the balance settings on your PC audio contoler, you'll need to go into your sound options.
3) Could be the vocoders or lack thereof in you DVD player software. Try VLC Media Player, its free from here:- http://www.filehippo.com/download_vlc/
Sep 08, 2011 | Computers & Internet
Sudden problem: voices can't be heard, everything else normal.
If this is on a home made dvd then that is probably where you the problem is.
If you try a proper store bought dvd and that works then you know its the other dvd.
But if a proper store bought dvd give the same errors then it could b a setting or part of the sound replay circuits that have or ore dying
Aug 17, 2009 | Sony DVP-NS575P DVD Player
Technics SH GE70 : 1 bar doesn't do much
I would want to know if it's just an indiction problem or an actual notch.
Let's prove the signal is pure going to the EQ.
Tune between FM stations with no automatic muting on your receiver so you can hear a loud hiss. Monitor the EQ display. There should be a lot of energy across the bands. If you see the notch swap the inputs to the EQ to prove it's in the EQ. Otherwise the signal is being affected upstream.
Let's prove there's no audible notch in the bandwidth. This is the fun part.
Set your system to just play Stereo with the FM hiss and if there is a Stereo Direct setting that bypasses internal circuitry, engage it. Adjust the EQ for equal level and flat response on both channels.
Disconnect the two front speakers. Wire just one front speaker across just the Positive leads of the Left and Right amplifiers. This is not dangerous. (**)
** Back in the day we used this kind of wiring (with some proper resistance and circuitry to prevent interaction between the front channel speakers) to extract ambience (difference) information from plain stereo to drive a speaker at the rear of the room. Adjustment was done by selecting MONO and turning the Balance control for Minimum output, then going back to Stereo for listening. Ah, the old days.
What this does is make the speaker play only what is DIFFERENT between the channels. If the source is truly MONO as it should be there will be a minimal output presented to the speaker. In an ideal world a true mono signal fed to both channels in this manner would result in total silence. There will always be some difference in the real world.
You can prove the accuracy and fullness of the EQ signal by adjusting one channel of the EQ to be different and as you do the sound should start to rise as the Delta increases. Returning the controls to flat and equal should provide minimal output. If there is a solid audible difference in the treble range the EQ might actually be showing the 6.3khz deficiency accurately. To see if it's at 6.3khz adjust the LEFT channel downward to match the display of the RIGHT and the difference program material should become very low as heard from the speaker. That would indicate a true deficiency in the LEFT channel.
Fixing it might not be possible but you might be able to use the EQ to offset it.
Apr 29, 2009 | Technics SH-GE70 Home Equalizer
Very low volume.
If you get the remote look under menu see sound settings, otherwise somewhere under menu should be a reset option do try that
Nov 10, 2008 | Koss KS3102 System
Can hear everything except the te voices in movies.
You could try hitting the dynamic compression button on the remote and that makes the highs and lows close im not sure if this will help but it might and another thing you can do is hit the front green button up more so it will be louder hope this helps
Jun 08, 2008 | Spherex Xbox 5.1 Surround Sound System...
Bass frequncy
Although I am not familiar with the Zoom HD 8 Track I am a former sound engineer so may be able to offer some general advice.
Firstly, because the wave pattern of low frequencies is very long, there are a number of things that will greatly effect bass response caused by standing waves.
1) The position of your bass monitors. Ideally these should be low down but not directly on the floor, especially if the flooring is wooden.
2) Try your monitors/speakers at a slightly different angle. Bass can bounce off walls, back towards the sound source and phase out the signal, rather like a noise cancelling system.
3) Try listening to the sound in different areas of the room. You will be amazed at how the sound pressure level will vary, simply by you moving from one position to another.
4) Never put bass tracks exactly at centre, always offset them slighly by a few degrees left or right.
5) Do some of your mixing using headphones, you will not have to worry about standing waves. But remember that things sound very different on speakers in free space.
Strangely, the reason you are getting distortion when you turn things up is probably because your bass is on the verge of over modulation to start with. Really bass is felt, not heard. You could try is to decrease your mid and high frequencies a little. The ratio between high frequencies and low ones will then increase by default and your bass may feel heavier.
What are you mixing?
Dec 31, 2007 | Koss EQ50 Home Equalizer
Sometimes voices are low on playing of music/films
hello Mike
Well, it sound to (recording ) on each songs, depending on how it record, if happen only with some , it is no problem but if all songs you play happend then its a problem with the drivers, or program to control your music, try to down a notch on control panel the hardware acceleration. it solve a lot problems of this kind, or reinstall the drivers for the sound card.
Good Luck
Nov 20, 2007 | Logitech X-530 Computer Speakers
Headset Doesn't Work...
hi Ive got a logitech headset 250 but I cant use that in my laptop and why !??
pleale help me!
see yah bye for now
Nov 13, 2007 | Logitech 250 Headset
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Open Questions:
See all Cerwin Vega E-76C Center Speaker Questions
Cerwin Vega E-76C Center Speaker Logo
109 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
