Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Gasket for model wm2377cw filter lg tromm - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
2 Suggested Answers
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
On my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Nov 28, 2009 | LG WM1814CW Front Load Washer
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
  • Hi
  • Try these:
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm
Place a good level on the top of the machine where it is flat. Check front to back and side to side. Level machine exactly. Now put a load in and when it spins feel the feet for any that are not solid on the floor. Adjust the foot down until the machine stops shaking.
Apr 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
