Question about Dometic Rooftop RV Air Conditioner
Air comes on but compressor doesn't come on. - Dometic Rooftop RV Air Conditioner
  • 24 Answers
You may have a bad start capacitor on the compressor. They make a replacement part that works with different compressors depending on the HP. it plugs into the three terminals and wires into the two power wires going to it.
Posted on Oct 06, 2010
  • jimmlnc1960 Oct 09, 2010
    if temp outside is below 65 would this keep compressor from kicking on. thanks
I have a 2004 Chevy trail blazer and the a/c max button will push in but the light doesn't come on and it still blows hot air
if the light doesnt come on the compressor is not engaging the clutch. possible wiring problem. check a/c clutch relay. may be faulty compressor or the system may be completely empty of refrigerant
Aug 10, 2012 | 2004 Chevrolet TrailBlazer
Compressor trys to start but doesn't
If the compressor is trying but not coming on then you will probably have to replace the start capacitor or get a hard start kit installed.Thank you.
Aug 26, 2011 | Whirlpool ACQ244XL Air Conditioner
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
Unit comes on, lcd light not flashing, fan works, ac doesn't
If the compressor is running check the thermostat, check the possibility that the gas is present and has not leaked out.
If so the pumping must be checked of the compressor , the pressure switch also must be checked.
Jul 05, 2011 | Amcor PLM12000E Portable Air Conditioner
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
The air does not come on at all but the fan will work.
mcdevito75 Here, You may need a charge of freon, turn the a/c unit off completely and remove plug from wall for about 5 minutes, then plug back into wall, now just put the fan on for 5 minutes, now the cool control, tiur that slowly to it"s coolest point and ss if compressor comes on, if so back off the cool control slowly just until the compressor goes off, if compressor doesn"t come on, contact a local a/c repair shop in your area. They come to the house.
Sep 01, 2010 | Amana Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
56 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
