Question about Sunbeam SNB542UCAS Built-in Dishwasher
I have a snb542ucas dishwasher with no power chord. I have been looking for a schematic to get it wired up with no sucess. where does one fined a wireing schematic for these that is just a quick reference to get this thing hooked up?
Tip
Air compressor will not start
An electric air compressor motor may start up fine on an empty tank but not when the tank has air in it. Additional torque and power is required to start when not empty. The electric wires may be too small or their length too long and represent electric resistance in the circuit. Larger gage wire will have less resistance and provide more power at motor start up under load.
A motor uses 6 times the amps when starting, a normall size and length wire is capable to deliver this power momentarily. The problem is when the wire is lengthened without using a larger gage wire. Resistance consumes power and the wire resistance will consume power causing a voltage drop to the motor. A motor, as most electric loads needs plus or minus 10% of its rated voltage to operate. What I'm saying is that a larger gage wire must be used, 1 gauge size to 25 feet, 2 gage sizes to 50 feet, or more size larger when using extension chords depending on length. I keep some romex of heavy gage with chord ends on it to use as temporaty long extension chord for compressor or welder use.
on Feb 12, 2015 | Air Tools & Compressors
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
Dishwasher contuallycuts out through entire run cycle
Hi Andrew - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 01, 2013 | Electrolux 23 in. ESL624 Built-in...
I changed complete sump ,main control board, display board,and fixed wires that were broken in tar now it will not power up thanks wm.
Carefully compare your wiring with the wiring schematic on the dishwasher....there usually is a schematic right inside the kickplate cover in an envelope...
If you have power going to it and it is not wiring now then the power is not getting to the right plaes inside...
heatman101
Dec 09, 2010 | Dishwashers
My sunbeam leaks out the front bottom of the door.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
e6623
Jan 01, 2010 | Sunbeam SNB542UCAS Built-in Dishwasher
Dishwasher won't run
some whirlpools have fuses in the control
panle
Jun 23, 2009 | Dishwashers
Htere is no power to the inlet valve
Check the power coming to the dishwasher, circuit breaker. Look at the wiring schematic to see where power comes from first, the control the door switch.
  • Make sure door is closed and properly latched.
  • If delay start option is available, has it been set and is unit still in time delay before starting.
  • Check to see if cycle is set correctly (refer to Operating Instructions in the "Use & Care Manual")
http://tclaundryrepair.com/
Feb 19, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Sunbeam SNB542UCAS Built-in Dishwasher Logo
Top Sunbeam Dishwashers Experts
Are you a Sunbeam Dishwasher Expert? Answer questions, earn points and help others
