Question about HP Computers & Internet
Cant get automatic updates from mirosoft.cant down load .cant find rundill 32 exe.cant find help suport .
    Problem Solver:
  • 18 Answers
What is rundll32.exe? Is rundll32.exe spyware or a virus?
This program is part of Windows, and is used to run program code in DLL files as if they were within the actual program. However, many viruses also use this name or similar ones. This file is also commonly used by spyware to launch its own malicious code.
Note: The rundll32.exe file is located in the folder C:\Windows\System32. In other cases, rundll32.exe is a virus, spyware, trojan or worm!
If you don't have this file in System32 then you have other problems. Possibly a virus is onboard.
Posted on Oct 06, 2010
Cant load even service pack 1
Go to windows update, " type " windows agent and click search, it will be slow to respond, when page changes scroll down and click on windows agent, wait till it loads page then scroll down until you see the download, top is for 32 bit, second one for a 64 bit computer and click, follow the prompt, this will update your registry, it may take several minutes for the window update symbol to appear, put your windows XP in the DVD driver, when windows opens close it. the disc will start when update begin, leave disc in until all updates are complete, check windows update to make you have all updates.
Mar 09, 2012 | Computers & Internet
I just purchased Spysweeper last week. It was working fine, and now it sits in "loading" mode without fully loading. I also had Microsoft Security Essentials (free) running, so uninstalled it...
Thank you, and I hope this helps...
There was a compatibility problem that existed between Webroot's Spy Sweeper program and Microsoft's Vista operating system. The issue occurred after an update Microsoft automatically delivered to Vista machines using its automatic windows updating function on January 8, 2008. The bug was fixed on February 12th, 2008. If you have automatic updates set on your Vista machine, the bug will have been corrected by now automatically.
Other issues may be: Check for firewall issues if you still have problems. Temporarily switch the firewall off and see if performance improves. Add exemptions to your firewall if you find it's the cause. SpySweeper.exe, SpySweeperUI.exe, ssu.exe and WrConsumerService.exe should be added and allowed to access the internet.
Jan 12, 2011 | Webroot Spy Sweeper (spysweeper) for PC
A mirosoft update service pack installed on my pc....now it just boots up and run components on my pc....then it just get stuck
A common problem. Go to microsofts web site and down load the help files on the download you have just received that caused the problem. You may have to uninstall it.
Oct 31, 2010 | Computers & Internet
Cant open mirosoft website
When you open your browser and it cannot load the web page that means there is no internet connection... if there is... then the connection is not stable..
Try this, could help you stabilize your connection...On the top of your web browser, on the File menu , uncheck the "Work Offline"...........If you are using a wireless internet connection.. disable the firewall setting of your windows so that windows will allow the connection of internet and will not be strict...If you are using a broadband router make sure it is receiving high signal... and make sure to keep away the unit 1 meter from any live wiring or wall outlet..
I hope that solve your connection issues..
Much appreciated if you rate this help..thanks..
May 24, 2010 | Toshiba Satellite P35-S605 Notebook
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Cant load drivers for aiptek 3 in 1 pen camera
You may have to run the .exe files to install the actual driver(s)
Apr 12, 2017 | Aiptek PenCam Trio VGA Digital Camera
Rundill error fixing
reinstall window xp or try to restore your pc
Mar 22, 2009 | Microsoft Windows XP Professional
Will not down load on Mirosoft Vista Platfrom...
w-10 is not recognized in vista. call or email olympus tech for the downloads for your vn-960pc
Aug 22, 2008 | Olympus WS-100 Digital Voice Recorder
Vista compatible software can be downloaded here:
http://downloads.olympus-europa.com/consumer/VoiceRecorder/720/eng_2000_xp.zip
After installing the software you need to install following updates
http://www.olympusamerica.com/files/DWPUP4EN.zip
http://www.olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
The software will work with the 32 bit edition of win Vista, not with the 64 bit edition.
Oct 21, 2007 | Olympus VN-960PC
Computers & Internet Logo
223 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
