Question about Lexicon MC-1 Amplifier
Volume has started to fade
I have a Lexicon MC1 which has been working fine for the last 6 years. it was properly setup by a specialist. Recently the volume has started to drop to zero on its own accord and has to be put back up manually. Other times when watching movies the sound goes all fuzzy and the only way to hear anything meaningful is to put it on 2 channel. DTS, THX 5.1, 7.1 all sound awful. Any ideas?
Any assistance would be greatly appreciated.
Thanks,
Danny
  • DannyPara May 29, 2008
    robotek,
    Many Thanks for the prompt response. I have access to a good solderer but how will I know which joints need re-soldering? I haven't opened up the case yet to take a look but I can guess that there will be a lot of electronics in there.
    Many Thanks again,
    DannyPara
  • DannyPara Jun 02, 2008
    robotek,
    Many thanks for taking the time to assist me. I still need to find the time to get the unit to an Electrician in order to get the soldering done. I will report back once that has been completed.
    Your help is greatly appreciated.
    Danny
  • 1,512 Answers
HI DannyPara
If the problems are intermittent, then the amp will most probably be suffering from dry solder joints. This is not uncommon about power devices in the unit like output stages and power regulators. I suggest that the amp needs to be checked over for such problems, and where needed resoldered to bring it back to a reliable state. If you are a gun with a soldering iron, you could do it your self. For this sort of work, I prefer to use solder with a 2% silver content as it produces a mechanically stronger soldered joint, and has a higher resistance to failure from the rigours of heating and cooling that constantly happens in amplifiers. If you think you dont have the skills required(good quality soldering is an practiced, and aquired skill), then get it into a decent repair guy for some attention. If you dont fix these problems,new faults may manifest themselves, and even expensive failures to output stages if left unattended.
Happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • Graeme Ross
    Graeme Ross May 30, 2008
    I would start with the power supplies, and audio power output stages. Any area that has has heatsinks, or where browning of the PCB is occurring, or just plain suspect looking joints. I also like to spend some time thouroughly inspecting the soldering of the PCB's under good light.
    I have a term that I use to describe this sort of work. BLANKET RESOLDERING. Pretty much means resoldering everything that may need it, or even not need it. Failing solder joints can be very difficult to find with the eye. You can often test for these sorts of problems by heating areas with a hair blow dryer(dont get too carried away with the heat), and then gentle repetitive tapping of the PCB in that area may help to locate the section that is contributing to the problem, and help to prove that you have indeed fixed it. The same percussive technique can isolate the problem whilst the unit is actually faulting also. Good Luck :) Let me know how you go. :)
    regards
    robotek
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
Amplification does not work
It sounds like a source slecton issue. Try the following and if that does not help I would start with a simple stereo setup and source and work up from there.
The RV-8 is powered on, but there is no audio.
1. Make sure volume level is audible. Volume level can be
increased with the front-panel volume knob or the remote
control VOL �� and �� buttons.
2. Make sure audio has not been muted. The message “MUTE
ON” or “FULL MUTE ON” will appear in the on-screen and
front-panel displays when audio has been muted. To deactivate
mute, press the Mute button or adjust the volume level.
3. Check the INPUT SETUP menu DIGITAL IN and ANALOG IN
parameters to ensure the appropriate audio connector is assigned
to the selected input.
4. Make sure the RV-8 is receiving an audio signal. To do this,
follow the instructions that begin on page 2-29 to open the
STATUS menu for the current input source. Hint: (Use the "STAT2" Button on the remote.)
Apr 29, 2009 | Lexicon RV-8 V2.0 Amplifier
Voice volume fading on my Motorla V551 cell phone
maybe the problem is the mouth piece or the ear piece of your fine.. you can bring it to the repair shop..
Mar 20, 2009 | Motorola Mobility V551
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon MC-1 Amplifier Logo
171 people viewed this question
Top Lexicon Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
