Question about Kenmore Dryers
I have a kenmore dryer mod #68942892 when i start it up it heats up and than the heating element turns off but the dryer keeps running , i have replaced the fuse and the senser on the heat tube still the same thing
  • Jason Reaves Oct 06, 2010
    Turns off for how long?
  • joe_cartoon7 Oct 07, 2010
    i took out the heater tested it and it is good , also i have replaced the thermo Fuse and the thermostat on the heat tube . it will get hot for about 5 Seconds and then turns off and wont come back on for a long time ?
  • 262 Answers
There are 2 Thermostats on the heat tube and 2 on the blower housing.
one of them on the blower housing is a thermo Fuse. the other is a thermostat
one of them on the heater tube is a hi limit cut off. the other should be a thermostat.
first i would use your heat selector switch to determin if this makes a difference or
you might want to take the heater out and inspect it, to make sure it is not broken. Please make sure you unplug the machine when doing this.
Most common problem is one of the 4 thermostats or the heater.
Good luck
Posted on Oct 06, 2010
  • 1 more comment
    the heater is good and i have replaced the Thermostats and the thermo Fuse on the heat tube but the heater comes on for about 5 seconds and then turns off for at least 90 min , but the dryer keeps running just no heat .
  • Donald  Rowan
    Donald Rowan Oct 09, 2010
    I'm Sorry but at this juction you will need a tech. Problem could be in the switch in the motor or the timer or a bad wire ..... it could even be in the outlet or cord.
    After the heater goes off you will need to find out how far the 220 v gets.
  • Donald  Rowan
    you should also check the vent.
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Jun 22, 2014 | Kenmore Dryers
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer
its the switch on the motor.
it has a mechanical interlock where in the heater should not be energize if the motor is not running.
that is the defective part. the contacts could have been welded together.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Dryers
My dryer is a Roper mod # rex 3615ew1 it runs but not heating ?
first of all check your breaker. turn it off and back on. sometimes only one breaker will trip causing it to run with no heat.
other causes: heating element thermo switch burnt wire or cord ...
May 03, 2008 | Kenmore 63942 Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
76 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
